left front wheel speed sensor is more then likely due, to a malfunction sensor for the abs sensor, badly connected sensor, or wiring, or contacts corroded or damaged, the knock sensor is usualy do to a fault sensor at the crank shaft where the timing belt is due, this is also more then likely to your engine turnover problems and is just coincidence when refueiling
Get a long shank screw driver and place it on the starter. While a friend attempts to start the car, tap the handle of the screw driver with a ball pin hammer. Sounds like the pin is catching upon deployment. Eventually your going to need to replace the solenoid and the starter.
I HAVE AN 04 ACURA RSX 2.0LV-TECH, AND IVE REPLACED THE BATTERY BUT ITS STILL ACTING LIKE THE BATTERY IS DEAD AND ITS SLUGGISH TO TURN OVER. IM LEANING TOWARDS THE STARTER BUT WOULD LIKE A SECOND OPINION.
It sounds like the Neutral safety switch on the clutch pedal or a starter problem. Try pushing the clutch pedal REAL FAR DOWN while starting. If it works have the switch adjusted. If that isn't the problem try a jump start. If that doesn't work, a starter may be be needed. Try tapping on the starter with a wrench then start.
