Columbia Sportswear Fun Run Jogger Stroller Logo
Posted on Nov 22, 2009
I'm having problems getting the front swivel wheel to stay in the swivel position. It ends up in the locked position.
2helpful
I bought a second hand stroller, quinny freestyle 3xl comfort. I did not get the user manual and i forgot to ask how to block the swivel wheel in the front. Can you help me?
According to the manual:
To lock it into the fixed position, rotate the swivel lock until 2 straight arrows appear in the display.
11helpful
Does the steering wheel control the wheels? Are the front wheels supposed swivel or stay in one direction?
theres no problem no the wheels arnt turned with steering wheel and the front wheels are supposed to swivel hope this helps if yes please giv thumbs up thanks
Front wheel wont swivel
check for missing bearings in the swivel section
loose or worn shaft
replace the front wheel swivel unit
Baby trend double jogger stroller pulls to the left when front wheel is in locked position AND front wheel wobbles (cannot push through it)when on swivel.
Hey! I just fixed my shaking wheel! There is a red lever above the swivel wheel. I pushed it up. And guess what... I can jog with my stroller!
1helpful
The swivel lock 'knob' for my buggy
www.buggypitstop.co.uk will be able to help you they are the only company that services prams and pushchairs and they will be able to help you with your phil n ted. You can turn the knob 45 degress and that should sort out your problem.
Apr 15, 2010 • Baby Gear
Swiveling Problems
Sounds like a loose bolt. Check under the front of your foot protector.
1helpful
Cant seem to get the front wheel to stay on swivel
I have the same stroller, and it's driving me nuts!
I saw this on a different post:
noavatar_s.gif sausagegirly
Rank: Apprentice
Rating: 100%, 1 votes
hi we had the same problem with our p&t sports buggy, brand new out of the box the front wheel kept locking, driving me mad! we contacted our supplier, kiddicare.com, who were extremely helpful and sent out a "front wheel swivel/fixed catch (screw fixing)" - it has WORKED WONDERS! the buggy is now smooth and easy to handle. you have to remove the old catch pin which can be a bit of a fiddle (when we got the old pin out it was a rivet fixing and very rusty) but only took us 10 minutes. highly recommended if you can get hold of one of these new screw fix pins, which have obviously been brought out to fix a common fault which p&t can't be bothered to recall lots of buggies and fix themselves...... ;)"
I've made contact with the store I've bought my e3 from, now, waiting to hear from them about this 'fix screw'. hopefully it'll solve our probs!
Good luck
3answers
Quinny Buzz front swivel wheel won't lock.
Make sure the wheel is central before trzing to lock it
2answers
Front wheels swivel and get stuck on each other
This is happening to my stroller and it turns out that the frame is bent. I have been unable to find a certified technician who is willing to fix it. I guess I can offer it for parts to someone.
1helpful
2answers
Problems with releasing front wheel lock
I have just fixed my stroller which had a similar problem. The wheel was still swivelling but it was sticking slightly. I noticed that the pin that locks the wheel in place was half out and therefore the wheel was getting caught on it. I undid the nut that holds the end of the wheel lock cable in place and tightened this as tight as I could which pulls the pin back into place (making sure that the switch is in swivel position). I then put the washer and nut back on (making sure cable was as tight as possible).
Top Columbia Sportswear Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Columbia Sportswear Baby Gear Expert? Answer questions, earn points and help others
