Click Start/Control Panel and look for Sound or Audio. Look inside it to see if Microphone is check as an Recording Device. If not the other party will never hear you. You can also get to Audio Sound by clicking the megaphone that is located at the bottom right near the time.
Depending on your operating system you can click Start/Program/Accessories/Entertainment/Sound Recorder you can test your microphone by using the sound recorder.
All you have to do is to install a video capture software http://www.megaupload.com/?d=Y99OK8XJ where you will be able to record an audio in the output of your computer. After that you have install this software http://eviosoft.com/audio-converters/audio-converter.html this will convert or pick up the audio of your video. There is an instruction there how to use that software. Hope this solve your problem.
most of some notebook computer had only mic capturing, when you talk someone on voicechat, they heard you but you can't hear on your notebook built-i speaker. if you want to check., if your mic is ok...try to record voice....using sound recorder of Windows.
you chack yuor sound device mic or click start manu programs accessories entertainment sound recorder and record your voice if you are active record you are success or faliure then speaker proferties record select mic
Have you tested the webcam's microphone on your own computer? It is an easy test. You can use any audio program such as Goldwave or the sound recorder found under XP Accessories--Entertainment. Additionally you can open Control Panel, select Sound and Audio Devices. Select the Voice tab.On the bottom right there is a Test hardware button. Another common problem is that certain software can mute the microphone when launched. You can check this by clicking the Volume icon in the systray. When it opens the window check to see if the mute is clicked anywhere. Uncheck if mute is checked. Finally, your soundcard manufacturer may have an icon in control panel. An example is RealTek HD Audio Sound effect manager. You may find a tab identifying the mixer. There is usually a series of adjustments for Mic Volume, Line Volume, and Stereo Mix. Make certain that the Mic Volume is not muted.
The ViviCam 3105s does not record any sound to go with its videos. You can add a soundtrack using video-editing software on a computer, but you cannot record one on the camera.
I know this wasn't the answer you wanted to see, but there it is.
go to ---->Start ------------->Programs ------------->Accessories ------------>Entertainment ------------->Sound Recorder option is there to record
configure u r Microphone properly and there if start record u can see some voice signals which is getting recorded just stop it and play it then u will hear the voice
go to control panel:-1-select-sound and audio devices.2-select audio3-in sound recording select your audio driver{creative or other}3-press volume you will see capture screen raise mic volume above and select check box under it.===enjoy recording.
Well, looks like you went through all the steps, but I'm wondering about one thing...
If you goto: Start -> Control Panel -> Sound and Audio devices
There are 5 tabs at the top, 2 of which you'll be paying attention to "audio" and "voice".
On these tabs are the record settings, which you will want to have the drivers for the m-audio in the record processes.
For instance, I have 4 options in the record process:
Logitech (mic built into camera)
SoundMax (sound card)
Bluetooth Audio (bluetooth server)
BlueTooth High quality audio (bluetooth server)
Out of the 4, I have logitech enabled in the record area (which isn't the right thing as the camera doesn't work anymore...jeez, found something that I need to fix on my PC now...)
