LeapFrog Tag Reading System Logo
Posted on Jun 28, 2017
Leapfrog tag audio download menu not visible
Tag audio download menu not visible
Ok, we are out of patience and need help. We have tried full installs and reinstalls 5 times Every time we get to the point of seeing the audio menu, it is not visible
We have loaded Adobe9 and still not there
Changed to recommended resolution settings
Oh, we are on a Mac ibook Intel chip
We have followed every single step
Anyone have a pointer or two
1 Related Answer
Anonymous
  • 100 Answers
  • Posted on May 03, 2010
SOURCE: Leapfrog tag will not recognise the book Cars Tractor Tipping
Hello
Please take a look at this link and go through the steps. http://leapfrog.custhelp.com/cgi-bin/leapfrog.cfg/php/enduser/std_adp.php?p_faqid=1638&p_created=1208987240
Please let me know if this helps you out.
Thank you
Testimonial: "The problem was with the country settings on the audio - it seems that the book I had was from the UK and not US. Thank you for your help."
2answers
Tag will not update
try downloading it on another system and transfer it to yours.
6helpful
Having and issue with the audio download on the Leapfrog Tag system. I have Leapfrog Connect installed on my Mac. Audio for books previously downloaded and newly downloaded are not able to be put on pen. I...
Just got this from LeapFrog. Worked for me, although it toook a couple of attempts.
For Macs:
Please try downloading and running this tool and connect the Tag Reader when prompted:
http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.dmg
For Windows machines:
1. Close the LeapFrog Connect application.
2. Double-click on this link http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.exe then click "Run."
3. Click "Unzip" to extract the files.
(You will be asked for a location to save the files. Save them to your Desktop or to another folder that you can easily find.)
4. After the files are extracted, find the "LeapFrogTagFixTool" folder on your Desktop (or where you saved the extracted files).
5. Open the folder and double-click the "TagFixTool.exe" file to open the LeapFrog Tag Repair Utility program.
6. Connect your Tag Reader to the computer. (Make sure your toy is powered on.)
7. To start the repair process, click the "Click once to fix your Tag Reader or Tag Junior" button.
8. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Jul 26, 2012 • Toys
2answers
I have lost the cables and cd i need to plug my leapfrog tag pen into my computer. can i buy these anywhere?
Regards, Tony
Jun 13, 2011 • Toys
Audio wont download onto tag junior
make sure leapfrog connect is installed correctly, then make sure you have the latest version of flash, after you download the audio, make sure you add it to the tag junior. you can do that by clicking "on my tag junior" on the left side under audio downloads and click add then it will sync.
Hi what does error code #1096 fault detail null mean?
Thanks for using Fixia.
Please try below instructions if they help .
You will want to use the LeapFrog Connect Tag Fixing Tool to see if you can resolve the issue. The instructions for Mac, and PC are listed below:
PC instructions:
1. Begin with LeapFrog Connect closed
2. Click here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.exe for the download executable file.
3. A File Download box should pop up. Select "Run"
4. You will be prompted for a location to download the program to, you will see a message "Unzip to folder"
5. Click Browse and select your desktop as the location to save the folder
6. Click "Unzip"
7. This should create a folder on your desktop named "LeapFrogTagFixTool
8. On XP: Open the folder and double click on the TagFixTool to open
9. On Vista or Windows 7: Open the folder and right click on the TagFixTool and select "Run As Administrator"
10. Connect the Tag Reader or Tag Junior to the computer and turn it on
11. Click the button "Click once to fix your Tag Reader or Tag Junior"
12. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Mac instructions:
1. Download the LeapFrogTagFixTool.dmg and mount the image. File is located here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.dmg
2. Drag the FixIt application into your Applications folder.
3. Close the LeapFrog Connect application (if it is open.)
4. From the Applications folder, double-click the FixIt application file to open the LeapFrog Tag Repair Utility program.
5. Connect your Tag Reader or Tag Junior to the computer.
6. To start the repair process, click the "Click once to fix your Tag Reader or Tag Junior" button.
7. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Note: Please be sure to be signed into your admin account and are connecting to a USB port directly on the computer, not a port on the keyboard or other hub.
8helpful
2helpful
2answers
LeapFrog Connect Application has encountered a problem and needs to close. We are sorry for the inconvenience. I don't know what to do. this is what I got both of my kids for Christmas and it doesn't work...
I would completely remove the software and reinstall it. I recently bought the Tag Jr after already having a regular Tag installed on my computer, and had to completely re-download everything. LeapFrog's website today also said that they were experiencing much higher than normal traffic, and some applications may not work as well or as fast.
Top LeapFrog Toys Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
