I have the directions for this item and tried to paste them here, but exceeded the amount of space allowed. Will send in several replies. FIRST: HOLIDAY LIVING HEAVY DUTY OUTDOOR DIGITAL POWER CENTER MODEL #LW28080 ITEM #0050024 INSTRUCTIONS: NOTE: To set up Timer for the first time, plug in the timer for 10 minutes, then insert a sharp pointed object or opened paper clip into the pin hole marked "RESET" to clear all settings. SET THE CURRENT TIME 1. Press the CLOCK button. 2. Press the DAY button to set the current day of the week. 3. Press the HOUR button to set the current hour. Be sure to take note of AM / PM. 4. Press the MIN button to set the current minute. 5. Press the ENTER button to finish setting the time. Note: If you do not touch any buttons for 10 seconds, it will automatically save the time. Continue to Digital Timer Mode or Photocell Timer mode below. To have your lights turn on and off at specific times throughout the week, choose Digital Timer Mode. To have your lights turn on every day at dusk and off at dawn or after 1 - 12 hours, choose Photocell Timer Mode.
SECOND REPLY: DIGITAL TIMER MODE Note: Be sure to first set the current time as indicated above. 1. Press the Timer/Photocell button to switch between timer modes - to use the digital timer, press the button until you see TIMER on screen. 2. Press the PROGRAM button once to set a program event. We will start with "Program 1 ON" - we will now set the "On" time for Program 1 Note: Each program is an On and Off setting. For example, to have your lights turn on and of the same time every day of the week, you only need to use Program 1. 3. Press the DAY button to set the day of the week for the lights to turn on. Keep pressing the button until your choice appears. The choices are: MO - Monday Only FR - Friday Only SA-SU - Weekends TU - Tuesday Only SA - Saturday Only MO-SA - Monday through Saturday WE - Wednesday Only SU - Sunday Only MO-SU - Every Day TH - Thursday Only MO-FR - Weekdays 4. Press the HOUR button to set the current hour. Be sure to take note of AM / PM. 5. Press the MIN button to set the current minute. 6. Press PROGRAM again to set "Program 1 OFF" and set the Off time using steps 3-5. 7. To set additional On/Off programs, repeat the steps above. You can set up to 7 On/Off events. 8. When finished setting the program, press ENTER. Note: If you do not touch any buttons for 10 seconds, it will automatically save the program.
THIRD REPLY: PHOTOCELL TIMER MODE 1. Press the Timer/Photocell button to switch between timer modes - to use the Photocell Timer, press the button until you see below display on screen. On at Dusk OFF 0:00 At Dawn 2. Press the PROGRAM button to set the Off time: OFF at Dawn - The timer will turn on at dusk and turn off at dawn. Hours after Dusk - The timer will turn on at dusk and turn off a set time later. 3. If you chose "Hours after Dusk", press the HOUR button to choose the number of hours the timer should stay on, from 1 -12 hours. 4. When finished setting the program, press ENTER. Note: If you do not touch any buttons for 10 seconds, it will automatically save the program. OVERRIDING TIMER SETTINGS The ON / OFF buttons override the current programmed events. To override the current program (either ON or OFF), press the ON/OFF button. NOTE: If the timer is not in "Manual" mode, it will obey the next programmed event. This allows the user to manually turn a light on and allow the program to shut the light back off at a preset time. REVIEWING PROGRAMMED EVENTS In the current time display, press the PROGRAM button repeatedly to check your settings. When finished, pressing the ENTER button or leave the unit over 10 seconds to return the display to the time of day.
Yea, yea, yea. All of the directions are great, but I bought two (2) of these #LW28080 timers at the same time at Lowes. Both are exactly alike.... dead! The red lighted switch on the side is lighted and stays on, doing nothing. That's it, that's all. Everything is dead! Receptacles stay dead. No readout, no nothing! All I can read on the blogs or in the so-called instructions is the startup steps...., plug it in for 10+ minutes, paper clip to set the reset, and so........ There is absolutely NO display in the window... on neither timer, never! I cannot get a straight answer from the factory website or the public, just the startup procedure which does nothing. At 1:30pm Central Time, Thursday, 6-1-17, I called Customer Service and got a telephone recording that says to call back during "regular" business hours of 10am-6pm EST, M-F! This is a Mickey Mouse piece of dog droppings, manufactured by a Mickey Mouse company!
SOURCE: I've lost the instructions for
I think the Holiday Living yard stake is made by Woods.
GE sells identical 6-outlet yard stake for which I have a manual with clear instructions and images:
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
Add a comment to help me identify your timer so others will be helped also.
If manual shown above is incorrect, open link below to view general list of yard stakes with manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#yard-stake
SOURCE: Need instructions for Holiday Living Yard Stake
The following link shows several yard stakes on the market today plus operating manuals:
I cannot find photo of the holiday living yard stake 6 outlet programmable timer.
But I think Holiday Living is same as Westinghouse 28018
See 28018 at Amazon
http://www.amazon.com/Westinghouse-28010-Weather-6-Outlet-Photocell/dp/B004A16LTO/ref=sr_1_39?ie=UTF8&qid=1292415078&sr=8-39
If this is not your timer, or timer does not show on first link, add a comment and provide feedback.
Let us know where you purchased the product and give more detailes about the product so we can provide correct answer.
Your information will help fixya community better serve folks who want free answers.
