Washing Machines Logo
Posted on Nov 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Loud bang during dryer rotation. front loaded dryer. dryer is six years old. bang is with evry rotation of drum.
Anonymous
Level 2:
  • Expert 106 Answers
  • Posted on Nov 21, 2009
Anonymous
Expert
Level 2:
Answers
106
Questions
0
Helped
39227
Points
331
Not nkowing what brand, I would guess its a maytag or one of their brands. It sounds like a screw that mounts one of the paddles inside the drum has backed out and is now poking out the out side of the drum hitting the cabnet as it goes around. Un plug it , pop the top open , rotate the drum clock wise by hand slowly to see if a screw is standing up on drum.
If its a whirpool dryer with the lint filter inside the door, the top cabnet is dented down, hitting the drum.
someone sat on the top, bent it down.
2answers
Hoover zodiac 12 480 front load washing machine does loud banging during spin cycle.
check the drum has no coins in it if that fails you spindle bearing needs replaced
Six-year-old Frigidaire stackable front-loading washing machine turns on, fills up with water, but makes a loud noise during the spin cycle?
If it is a banging or uneven sound, your tub and unit is not balanced any further. The tub could be off of the pulley/bearing supports and needs professional attention.
6helpful
2answers
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Loud banging noise during final high speed spin
I have the HE3T which is 6 yo. Last week it started making a loud banging noise in the spin cycle. I had a repairman come out. He said it is the drum bearings. He said that it is a problem with these machines and to call Sears. He said that the drum and bearing is one assembly and that Sears should cover it.
I called today and Sears todl me that I have to pay for a Sears technician to come out a determine if it is indeed the problem. If so, it will be covered under the lifetime warranty on the drum. I have to pay for the service call $75.00 and if it is the problem, I will be reimbursed. Cross my fingers!
Maytag LAT9806AAE- Top Load Waher- Loud Banging During Spin Cy
Damper pads, P/N 203956, $23 at searspartsdirect.com might do the job. Can't put them in yourself though, unless you are the Maytag man. Look for felt pads at the bottom of the cabinet or black dust around the damper at the bottom.
Other, more expensive problems might be a warped drum or a bad transmission. Are the springs o.k.?
2answers
Hear a periodic banging during rotation of the drume
usually you can check it at the back cover, check if the dryer tub is directly mounted or connected to the motor, then check the rubber stabilizer or spring stabilizer of the motor which is connected to the base. This stabilizers are responsible of the balance of the dryer tub during high speed operation or rotation of the motor. check this stabilizers and replace it if it is defective or weak.
and one thing more, just make sure that when load your wet clothes see to it that you load it at the center of the dryer tub, so that when the motor starts to spin at speed it is in a balance position.
22helpful
3answers
Loud noise
First, UNPLUG YOUR DRYER! Now open the dryer door and remove the 2 screws at the door hinges... remove the door and set aside, then remove the 2 screws opposite the hinges. Grasp the front panel near the top, just below the top panel and pull it toward you... do this on both sides. Tilt the panel forward then lift it off of the lower clips.
With the front panel gone, you'll see a 5/16" screw just below the top panel on both sides, top left and right. Remove these and the clips too... now you can lift the top panel like the hood of your car.
To gain further access, remove the 6 (3 on each side) screws holding the front drum support/blower vent panel, then set this aside.
If you want to remove the drum... first, take a flashlight and look closely at how the belt is routed around the idler pulley and the motor shaft. (You'll have to re-route it for reassembly.) Reach in there with both hands, with one hand rotate the spring loaded idler pulley back to release tension off the belt, then with the other hand remove the belt from the motor shaft. Now lift and pull the drum out the front of the cabinet.
Check to make sure the rollers in the back rotate freely. You can remove the rollers, buff the roller shafts with emery cloth, lube the shaft with light oil (like sewing machine oil) and reinstall the rollers. Lube the idler pulley also. Rotate the motor by hand and listen for the squeak you described.
Also check the front drum support panel you removed earlier. The drum rides on this as it rotates... As you are looking at the drum support from the drum side, inspect the 10 o'clock to the 2 o'clock area closely. If the glides (teflon) are worn it'll squeak when it rotates.
Hope this helps. Oh yeah! Almost forgot.... the belt won't squeak at all. It'll be the motor, rollers or drum glides.
Top Washing Machines Experts
john h
