It could be a bad circuit that shorts or a corrupt driver. Most likely you are going to need to take this to a repair shop and have it looked at as most of the diagnostics are going to require extensive circuitry knowledge and disassembly of the machine. If you can boot the machine in safe mode and it works try checking your hibernation setting in safe mode. You can press F-8 when the machine is booting or force it to allow you the option for safe mode by starting the machine when you are on battery power and about 20 sec after the Windows logo appears drop the battery out while you are not connected to main power.
