When i boot up the xps 410 the screen goes to dollar signs with text written over them? the system goes into a repair mode and does not start windows Vista
when you start up your computer press f8 a menu will come up select Last know configuration that worked press enter.see if that works.If not press f8 again and select safe mode press enter see if it will boot to safe mode.if it boots go to my computer right click your boot drive select double click tools then click check now button a menu will come up tick automatic repair then start repair.It will ask you to shedule a repair click ok when you restart it will check and repair your hard drive.If this does not work you can put your operating system disk in your drive and boot to it and click repair and follow the on screen instructions
According the the dell specification you can only install up to 4gb, so I don't understand you saying that you were upgrading from 3gb to 6gb. Make sure that all the ram that is installed is of the same brand and speed (667 / 800 MHz Dual Channel Dual DDR2 SDRAM). The fact that it is saying no boot device also would suggest that it is possibly something wrong with your harddrive, whether it was corrupted or damaged while you were changing the RAM, if you have a spare harddrive try installing and booting from it. If that doesn't work it could be a motherboard issue, which the BIOS should be update, all the jumpers on the board should be checked etc. Its rather hard to diagnose a problem such as this, and the fact that after you installed the new RAM, even the old RAM would not work, suggests that you may have damaged something while messing around in the computer.
probably have to replace the hard drive as the first boot instruction ( boot from hard drive) is not executable , so the bios is looking for alternative sources to boot from as per the priorities set in the boot sequence
of the hard drive is dead - replace it with an sshd unit rather than a disc hd because in the sshd there are no moving parts to cause the problem and they are quicker to boot up
Go into safe mode Under settings, control panel, power options set "turn off monitor to never reboot
I think this is not a sleep problem but the incorrect monitor settings were set. This will cause the screen to go black when the OS comes up. Boot in safe mode and change the display settings to 640x480 OR in safe mode, delete your monitor. When you reboot it will load a default monitor and you should be OK
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
Click on Start and then Run.
In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
Note: Do not make changes in the System Configuration Utility
other than those outlined here to avoid causing serious system issues.
This utility controls a number of startup activities other than those
involved with Safe Mode.
Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
Check the checkbox next to /SAFEBOOT and click OK.
You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
After the restart, the PC will automatically boot into Windows XP Safe Mode.
Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
This will again open the System Configuration Utility program.
Choose the Normal Startup radio button and click OK.
After the restart, the PC will boot into Windows XP normally and will continue to do so.
Boot into Safe Mode and change the video resolution to the lowest resolution supported. Reboot the machine normally. The problem should have disappeared. From here you can readjust your display resolution to any higher resolution supported by the system if you wish.
