Its the antenna problem.either the antenna itself is faulty.but if you have got the antenna checked and its proper then its problem with the connection of antenna.the place where antenna connects is got shorted or the antenna is not got conneted there properly.but if the antenna is old replace the antenna and check out.
Sirius Radio boasts no commercial interruptions with its satellite radio subscription; but, from time to time there are interruptions in the signal. The good news is that problems are usually easy to solve. Most of the time, the solution is as simple as proper placement of the antenna or properly docking the Sirius Radio.
Signal Obstruction While Driving
Signal Obstruction in Your Home
Antenna Not Detected
that means the antenna is proper and not faulty so it shows full signal.but antenna is not connected properly to its connecting place or the connecting place of the antenna is faulty.so its not receiving signal but showing full signal.
the connecting place has to be checked by meter and continuity tester to locate the fault and confirm it.
thanks for keeping updated.
the radio incates full strength in signal
radio indicates full strength signal
