NetGear DG834G Router Logo
Posted on Nov 20, 2009
Laptop won't connect to router wirelessly. need to find out router password
Anonymous
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Nov 20, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
3926
Points
61
You dont need the password unless you have set one up , if you have and forgoten it then press the reset button on the rear of the router. you might need a pin to press in a small hole on the bottom
Belkin n750 db connects with windows 7 laptop, but will not connect with xp laptop. It will not let me enter the password.
It is possible that, if you have the router set to wireless N only, your XP machine won't interact with it. Your XP adapter probably doesn't support wireless "N"--you'll have to tell the router to use "N" or "G"
2helpful
Forgotton wireless connection password
Hello jenhardy640,
You just need to reset your router so you won't need any password to connect to it. Look at the back of your router for the reset button. And then using a pin, press and hold it for about ten seconds. That will restore it to factory settings and remove the password.
You can rate my answer if you appreciate it.
Thanks!
-damneddle
Hello, My D-Link DGL-4500 router won't work properly. The wireless portion will not work. I know the Username & Password. But no device I have will connect to it wirelessly. It'll connect...
If the default password on the D-Link has been changed then-
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Won't connect to wifi
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
4helpful
Wireless signal gets to laptop , but won't connect
you need to setup WPA2 password for your network to access.
I have got a 2nd laptop and cant remenber my password to connect it to my wireless connection
If yuor first laptop is able to connect then try installing SIW on it and click the PASSWORDS link to see if it will retrieve the wireless password off the first laptop.
If not, and you cannot get into the router either, you will need to reset the netgear to factory by depressing the reset button in the back for 10 seconds, which resets the login to 'admin' and the password to 'password' to allow access to the router, and setting the wireless security to NONE - allowing you to change it to something you can remember.
If you are able to get into the router, but simply cannot remember the wireless password, you can reset it to something else without resetting the router through the wireless security menu in the router. You will need to then set both laptops to use the new password.
Can not connect with my home computer.Router and modem working,just won,t connect
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
3com 3CRWER200-75 wireless router won´t connect to certain sites
first coonect your wifi router witjh your laptop with ether net then go to this link
http://192.168.0.1
then type user :admin and password also admin or blank
then go to dhcp then enbale it with auto .
then disconnect your cable from laptop.
then go to my network places then find wireless network then simply conect your network.
thtas it.
5answers
Method to add another laptop to wireless Linksys in home. Model no: WRT546 Serial no. CDFF1G506178 password lost...tried ADMIN
just try reset in your linksys and reinstall once again the driver for it in both your laptop and set a password for it .....
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
