On model 5851-21, which only has four buttons: Hour, Minute, Timer/Reset, and Start/Stop -- here is how to set the time for the (somewhat hidden) Clock mode (for Time of Day, not countdown).
To switch to Clock mode, press the Timer/Reset and Start/Stop buttons at the same time. (To switch back to Timer mode press the Timer/Reset button.)
To set the Clock time, hold the start/stop button for 6 seconds until the display is flashing. Now use the Hour button and the Minute button to set the current time. Press the Start/Stop button when done.
(Full model number I have, and used for reference is 5851-21 0410 V3043.)
My Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
SOURCE: How do I reset the
1. Press and hold the "Clock/Timer" button until you hear a beep and the time starts to flash.
2. Adjust the time using the "Hour" and "Minute" buttons. Note the clock includes AM/PM.
3. Tap the "Clock/Timer" button to restart the clock.
SOURCE: reset timer between batches of cookies
click the Hr/+ and the Min/- keys at the same time...the timer will reset.
Testimonial: "IMLOUISE YOU ARE A GENIUS!!! HOW DID YOU FIGURE THIS OUT? MY MISTAKE WAS THROWING AWAY THE INSTRUCTIONS. I THOUGHT IT WOULD BE EASIER TO DO. "
