Make sure the pilot light flame looks blue, if it looks yellow, removed and clean the pilot light assy. afterward if it is still the same, I'll change the thermocouple first ( $5-$20 bucks ), for a 30+years old stove, most cases is the oven safety valve is out ( $150-$400 bucks ). If you are planning to keep the stove for a while, I'll change both. Good luck.
Your thermal couple may need to be replaced, but I suspect it is the solenoid valve that opens the gas supply. We have a similar problem.
A
pilot light will be found on natural gas stoves, fireplaces, clothes
dryers, water heaters and furnaces. When the gas is turned off, the
pilot light will go out on all of these appliances. After the gas is
turned back on, you must relight the pilot light before you can use the
appliance. Pilot lights are similar so if you can relight the pilot
light for a gas heater you can relight the pilot light for a gas stove
or any other gas appliance.
jQuery('.intro .thumbnail').each(function(i,e){
jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); });
Instructions Things You'll Need:
