Hi, I have got a Leisure Cookmaster 60 Double Oven and the lid which covers the hob will not stay up. Please can you advise me on what I can do. Is it possible to take the lid off?
The light may just be a burned out light bulb. Remove it and take it to an appliance store to find a replacement. As far as the oven goes, elements do burn out. They are relatively inexpensive. Make sure you have turned the oven OFF before you do anything. The heating elements do pull out and you can replace them yourself. Take the information about your oven and the heating element to an appliance store for a direct replacement.
Hello would you happen to have a model number or any serial number on your LEISURE COOKMASTER 101 I will be trying to obtain your specific manual and not provide one that is generalized and these numbers help to locate your exact unit. Thank you I await your reply Rick
remove rear panels (3; 1 white, 2 galvanised).
look under rear folded edge of hob. remove 2 screws in corners. dont lose 2 top hat rubber washers. from rear of cooker, lift hob slightly and push forward 1/2". lift hob off. dont over tighten new thermocouple union on back of valve (note how tight old one was)
