When someone set up my computer (Dell), they set it up using Outlook as the default program for me to get my email, which is fine. However, I have a Comcast Cable email address and when I am out of town and want to check my email via the internet (Comcast.net) my in box has always been empty. Is there a way for me to set it up so I can receive email in Outlook from my home computer but also check it from the Comcast site when I am not? Thanks in advance for your help!
Probably not. The email could have failed or numerous reasons. I always CTRL+A and CTRL+C before I post or submit any form online because things don't always work as planned and you have no control over someone else's site.
You could have been clicking on a mailto link and didn't have a default email client set. This would give you a MAPI error.
It could be that Outlook Express was setup as your default mail client but it's not setup to use, so it couldn't open the default folders and your email failed for this reason.
If you use an application on your desktop, then set it to be the default email client. If not, and you only use web-based email, then copy/paste to your email client instead of clicking submit.
Websites should send server-based email and these issues would be eliminated. Also, using mailto, allows spammers to harvest email addresses on websites. Although it can be written to make it difficult, most people don't make the effort.
If you are trying to send or receive an email in Microsoft Outlook and the password doesn't work, you can check a number of different things. Microsoft Outlook validates your email account with your email provider using various settings. Once it has validated your settings, it will send or receive email. It is not only useful to set up your email correctly but essential if you wish to use Microsoft Outlook.
Gather all of the email settings for your email account. These will be located on your email provider's website in an FAQ or support section. If in doubt contact your email provider to provide all of the settings. Look for any of the following terms: POP, SMTP, IMAP, SSL, SPA, server, and port number. Make a note of all of these. Determine when the problem exists. Check if the problem occurs when sending an email, receiving an email, or both. If the password error only happens with either sending or receiving, this narrows down the source of the problem. Click "Start," type "Outlook" and press "Enter" to open Microsoft Outlook. Click "File > Info > Account Settings." Select your email account and click "Change." Click the "Incoming mail server" field, if your error was when receiving email but not sending. Enter the full "incoming mail server" address as provided by your email provider. If your email is "IMAP" then change the "Account Type" to display "IMAP." Click "More Settings > Advanced." Make sure that the incoming server "Port" number is the same as your email provider stipulates. If your provider requires SSL, then click "This server requires an encrypted connection (SSL)." Click "OK." Click the "Outgoing mail server" field, if your error was when sending email. Enter the full outgoing server address. Click "More Settings > Advanced." Make sure the "Outgoing server" port is correctly set. If your email provider requires encryption, then select the correct type from the drop-down menu. Click "OK." Click the "password" field and make sure you have entered the correct password. If your mail provider requires "SPA," then click the "Require logon using Secure Password Authentication (SPA)" to enable it. Click "Next" and then "Finish." Your password should now work. Hope it helps.
Follow the below mentioned steps to set Outlook as your default email client.
Steps for Windows 7 and Vista -
- Click Start and in Start search box type 'default programs'. - In Search results, click default programs under Programs. - Now click on 'Set your default programs' and highlight Microsoft Outlook. - Click on 'Set this program as default' and click OK.
Steps for Windows XP and earlier platforms -
- Start Internet Explorer. Select Tools -> Internet Option -> Programs tab. - Under Email, select Microsoft Outlook and click OK.
To make Outlook Express Your Default Windows Email Program : 1.Make sure Outlook Express is not running.
2.Select Run... from the Start menu.
3.Type "msimn /reg" (excluding the quotation marks).
4.Hit Enter.Wait for, say, ten seconds for the process to finish. Nothing will appear on screen. Do not let that disturb you.
5.Launch Outlook Express.
6.Select Tools ' Options... from the menu.
7.Go to the General tab.
8.Click Make Default under Default Messaging Programs.Click OK
1) CLICK ON START
2) Go to ("Default programs" if You have windows 7 and vista) and ("set programs access and default" if you have Xp)
3) On windows 7 and vista. Click on "Set Default Programs" then choose you email provider ""yahoo, windos mail, or Outlook."
4) finally click on "' Set this program as default"
for XP just check the e-mail provider and click ok.
It sounds like you are trying to click on a hyperlink to email someone, like at a website. These hyperlinks are programmed to open an email client like Outlook, or Outlook Express and open a new mail message with the email address line populated.
If you are using a WEB based email like Yahoo, Hotmail and the like, then the hyperlink will not work, and you get the error you describe. Generally it isn't worth the time and effort to setup an email client if that is the only reason you are doing it.
SO, generally, I just open my email, then type the email address of the hyperlink ([email protected] for example)
you need to install a new account on your outlook or windows mail, turn it to default account, make outlook your default mail client and voila. everytime a program needs to initiate an e-mail message it will use microsoft outlook which is using g-mail as the default address
Using MAPI ( Messaging Application Program Interface) with Microsoft Outlook Express 5/6:
1. Start Microsoft Outlook
2. Go to Tools> Options.
3. Click Make Default under Default Messaging Programs- This application is NOT the default Mail handler.
4. Restart your computer.
Using MAPI with Microsoft Outlook:
Microsoft Outlook automatically sets up your MAPI E-mail program during installation. Make sure you M-O Email app. is properly set up with the right POP account name, password, SMTP mail host account, and other requirements. For further assistance, contact your Internet Service Provider *ISP* or systems administrator.
Usin Web-based E-mail Programs to Send Files *aol, yahoo etc...*:
Web based Email programs don't support MAPI functions. If you click on the Send button, it will not work. To send email files, follow the steps below:
1. Log in to your web based email service.
2.Compose a new email message.
3. Depending on your web based email service, look for the Attach, Attachments, or Insert option to attach your file. You will be prompted to browse for the desired file you want to attach. Change the directory to where you saved your file and attach the files.
I have not set up an e-mail account. How do I do this?
