Water-inlet valve
Most
cleaning problems are caused by the dishwasher not getting enough wash
water, so the water-inlet valve is often to blame. This valve is
usually at the bottom left or right of the dishwasher, behind the lower
access panel. It's the device with the main water line from the house,
a rubber tube to the dishwasher, and two wires attached to it.
When
a water-inlet valve is defective, you may hear the sound that's usually
referred to as "water hammer." If the water-inlet valve is defective,
you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Thanks for the prompt reply.
I should have added that the dishwasher seems to fill okay for pre-wash and rinse. Do you still think it's the inlet valve?
