Dell PowerEdge 4600 Server Logo
Posted on Nov 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bios for adapter 0 is not installed 4600 poweredge - system keeps rebooting, gets to windows screen, no login prompt and reboots and has the bios error
Anonymous
Level 2:
New Friend:
  • Expert 115 Answers
  • Posted on Nov 19, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
115
Questions
0
Helped
21711
Points
301
There are problem with Operating System ,It has been corrupted so pls re-install the operating system .
I cannot get the Dell PowerEdge 840 to recongize and of my HDD in the Raid array.. Trying to install the OS but tells my on HDD is detected
Then you need to get into the BIOS of the PERC RAID controller and inspect the state of the physical/logical volumes. Reboot the machine and watch for the prompt after the PERC5/6 RAID controller loads it's BIOS.
Considering this a null issue given the age, though...
tip
Little trick help you to reset Windows Password!
Method one: Login with the default administrator account
Step 1: Start Windows PC
Step 2: When you can see the Windows login screen, press ctrl+alt+del keys Twice and it’ll show Classic Login box
Step 3: Type Administrator as Username and leave the Password field blank
Step 4: Press the Enter Key and then you can be able to login the default windows administrator account which is it created by default when install windows.
Note: When you input the key combination Please don’t put the cursor on any account. And if you change the name or password before, you cannot login by this way.
Method two: TRY command prompt about password reset trick
1. Log in with any valid account.
2. Bring up the command prompt.
Type: net user
You get a list of accounts
Type: net user Administrator *
Type: net user (any account on that list) *
3. It prompts for a password. Enter one, then enter it again when prompted to confirm.
Now, try to log on as ‘Administrator’ with your new password. *
Please note that this might not work on a LIMITED account .
Method three : use a Windows Password Recovery cd
1. Visit the windows Password Recovery tool official site: http://www.windowspasswordsrecovery.com
2. Download the tool and run it
3. Burn the password reset cd to a blank CD/DVD or USB flash drive
4. Turn to the computer which you lost password, reboot it, insert the nearly created recovery disk.
5. Click Del key to load bios setting, set the system load from cd/dvd or usb, save the change
6. reboot the computer, load the password recovery software
7. select the windows os installation folder, select the user accout , reset the password
8. finish. you can login windows with a blank password now.
on Jul 12, 2010 • Computers & Internet
tip
Little trick help you to hack Windows Password!
little trick that might help you!
Step 2: When you can see the Windows login Password screen, press ctrl+alt+del keys Twice and it'll show Classic Login box
Note: When you input the key combination Please don't put the cursor on any account. And if you change the name or password before, you cannot login by this way.
Type: net user
Now, try to log on as 'Administrator' with your new password. *
http://www.windows7password.net/
7. select the windows os installation folder, select the user accout , reset Windows 7 password
on Jun 29, 2010 • Computers & Internet
Several attempts to install windows 2003 on dell optiplex 780 have been unsuccessful. all i get each time is a blue screen.
Windows 2003? There is no operating system called "Windows 2003". There is Windows 95, Windows 98, Windows ME, Windows 2000, Windows Milenium, Win Xp, Win Vista, Windows 7 ect. But no Windows 2003.
If you are trying to install an operating system on a Dell computer, put the disk in the cd or dvd drive on the pc and close it. Then turn the computer off and reboot it with the disk in the drive. After the computer reboots, it should recognize the disk in the drive and bring up the installation process automatically. Sometimes you have to reboot the computer 3 - 4 times in a row with the disk in the drive in order to get it to recognize the software and boot from that drive.
If the Dell does not have an operating system on it and you are trying to install windows from a disk, it may not auto recognize the program in the drive and the above instructions will not work. If this is the case, then you need to put the disk in the drive of the pc and restart/reboot it - and watch the computer screen as the pc restarts - look at the lower left side of the screen during the boot up process to see what keys you need to press to enter startup mode, or get into the bios system of the computer. when you boot up a pc, it will display the keys you need to press on the screen for a brief few seconds before the "windows" screen appears and it completes the start up. If the pc is running windows xp, the command keys to press during start up might be F2 - F8 or "press the delete key". The commands can differ depending on which version of windows you are using - and they can also vary by brand of pc too.
You need to put the pc into "safe mode" or get into the Bios system or restore area to install windows if the computer does not already have an operating system installed on it.
To put the pc into safe mode or get into the Bios System, you need to press the right keys during the start up - and do this before a picture appears on the screen or the windows display comes up.
Put the disk in the drive and reboot the pc. As soon as it starts to reboot, keep pressing the F8 key. If the pc does not go into Bios or say "loading safe mode" then immediately restart the pc and try again. Sometimes it takes 3 or 4 attempts to make this happen. If the F8 command does not work after 4 tries, then try the F2 key. After four tries if that does not work - try pressing the delete key.
If you can get the pc into the bios system - use the arrow keys on the keyboard to scroll through the options and find the prompt that says "boot order". change the boot order to boot from the Cd or Dvd drive instead of the hard drive. Save after changing this setting and reboot the pc with the disk in the drive and it should boot from that disk to install the operating system. Try rebooting 2 or 3 times after changing the boot order to the disk drive to get it to boot from the cd. Then just follow the prompts to install the operating system and your done!
2answers
How to install new microsoft XP operating system
This worked for me:
http://www.buildeasypc.com/sw/windows_xp.htm
I have to ad, that if putting the cd in to your computer and restarting it doesn't give you an option to install the windows xp, you should go to bios by pressing "del" key on your keyboard just after you reboot and altering the boot priority from bios. (it's different in some computers, so i can't give you the details, but you can browse around for the boot device priority setting, and if you are afraid that you have changed something that you didn't want to you can always just reboot without saving)
Dell poweredge 1800 bios not installed. how do I intall the bios? I bought it used.
enter the bios.F2
You can download the update CD from here. Also, you can update the bios from within windows with this utility (still requires reboot).
Keep getting checkpoint errors, and have changed Sys Battery , reset Bios and when i boot it ,it goes to Dell logo and keeps trying to reboot. Windows will not load.
Try going to the BIOS and see if it reboots from there. If it does, then it is most probably a hardware problem. You can try re-seating the memory modules and If you have multiple modules, try them one at a time.
If it does not reboot while you are in the BIOS, then the problem lies on Windows. Get your DELL Restore CD or your Operating System CD and insert it to the CD-ROM drive. Reboot the computer and press F12 while seeing the Dell logo, that should give you the options to boot to CD-ROM. It will give you a quick prompt of "press any key to boot to cd..". Make sure you press the space bar during this time to initiate the boot from CD-ROM.
Once the Windows Setup loads, Choose "Recovery Console" to repair your computer. Just choose the installation you would like to repair (normally it's number 1) then it will ask you for the administrator password. By default, the password is blank, but if you set a password for admin then use that password.
Once you get to the prompt, Type this command. "CHKDSK /R" (without the quotes). It will initiate the repair for your OS. This might take an hour or so. Just wait for it to finish and it will automatically reboot your computer. Let the computer computer reboot normally. You should be able to get to your normal windows screen back.
Good Luck.
1helpful
When I try to turn my computer on i have a blue screen message saying "A problem has been detected and windows has been shut down to prevent damage to your computer." I can't login or anything. I have even...
From your request, the question is very general.
Code Stop 0x0000007B, it means "inaccessible boot device": Windows is not able to read from the device it's supposed to be booting from. That device would normally be your hard drive - but if you're getting this during Windows installation, it could be something wrong with your CD or DVD drive..
The Stop 0x0000007B error message will be displayed on your screen with a lot of other information in what is know as the "Blue Screen Of Death" or "BSOD".
Different PCs have different "IDE or Sata interface default settings" depending on the OEM manufacturer specifications. Check your OEM motherboard require any BIOS updating.
If your PC is a desktop, remove all the PCI devices installed on the PCI slots.
If you can access to the CMOS BIOS, reset the settings to default, save the settings and reboot your computer.
If the your PC can access to windows, do a "chkdsk /f/r" from the "Command Prompt".
If not you have to reinstall the OS.
3answers
I want to break my password
remove the bios battery and try
I get a screen Microsoft WindowsXP that says my computer is locked and to sign in to unlock it.I have no idea what my password is. How do I correct this? Thanks
Dear Thumper:
If you set the password for windows please try the steps
below if it is bios password you need to contact your
computer manufacturer
Reboot your machine.
Press F8 before the Windows boot screen appears.
You will be be prompted with a boot options menu.
Select the Start Windows in Safe Mode option.
Click through several self-explanatory screens until your
reach the familiar 'Welcome' screen.
Note that this welcome screen is limited to 256 colors and
640x480 resolution because the primary graphics will have
been set to the Windows Safe Mode software VGA adapter. You
will not be able to change this mode even in Display options,
while Windows is running in Safe Mode.
Find the icon for the Administrator user. If the default
settings of your system haven't been changed, there should be
no password for this account.
The Safe Mode Welcome screen might display some of the other
users on your system.
Login as the admin.
Press Yes at the prompt asking if you would like to continue
using Safe Mode.
Continue on to the User Settings control panel. Here you can
change any of the other passwords for user on the machine.
Make any changes you want.
Reboot your computer. As long as you don't press any keys
(i.e. F8) during the boot-up the computer will startup
normally.
Login as the user for which you set the password.
Please feel free to get back to me If you need any further
assistance.
Regards,
Mohammed.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
