In a Hobart L800 you use 140 weight gear oil in the head and 90 weight gear oil in the planetary. You should start with about 160 ounces and check the sight glass and fill until in the middle of the site glass after oil settles.
instead of putting a gasket on tell him to take out all of the old grease out that is what has broken down and turning into oil causing a leak and if he can repace the seal around the agitator shaft replace the old grease with a high temp bearing grease or a good quality lithium grease
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
You can use a heavy weight gear oil or call the local hobart branch for it.To remove oil----Look under the mixer where the beater shaft is in the back and you will see a three quarter inch nut,remove this nut and drain the oil then put nut back in.To fill the unit remove the top cover screws and remove the top,you will see a long hexagon nut in length,remove this and grab a funnel then add the oil---be patient it takes time to fill as the oil is heavy.
Hi,im a hobart tech and know all these mixers well.What kind of mixer are you looking to write about?The differences are the sizes of bowls as 20qt,30qt,40qt,60,qt,80qt,140qt.Pick a mixer and i will write YOUR paper,but i want a fixya rating in return.
man you got an oldie but goodie mixer!im a hobart service tech for 8 years and have only seen about two dozen,unfortuantly parts for these units are exhuasted.as for the sight glass they do become cloudy over time and you cant determine the oil level.use a heavy gear case oil.the only way of telling is to drain the oil or if the unit is loud you should probably cange the oil.
