Question about Archos Internet Media Tablet MP3 Player
My Archos 7 doesn't seem to charge from the supplied USB cable. I left it in overnight and the battery is still almost dead. I've tried several computers (and they aren't in sleep mode). I hate to carry the charger when traveling (too many adapters, etc.) - but if I can't charge from my laptop, then I guess I will have to. Ideas?
    New Friend:
  • 131 Answers
Plug the laptop in with the AC adapter before you charge the tablet. When a laptop is on battery power, it may deliver less current to the USB ports. Or, the tablet might have a bad battery.
Posted on Oct 16, 2017
SOURCE:
SOURCE: broken archos
call archos repair 01709512012
Posted on Nov 11, 2007
SOURCE: How long can it possibly charge for the first time?
buy docking station
Posted on Feb 13, 2008
  • 3 Answers
SOURCE: Archos 604 wifi usb connection problem...
Okay, I just started reading your problem and started freaking out because it was happening to me and I suddenly thought that I would have to replace it. But luckily, my only problem was that I needed to prop-up my archos while it was plugged in. I would think that somewhere down the line, me and you have both knocked something loose in the connector. Luck to you, cheers.
Posted on Mar 24, 2008
andy1958
  • 14 Answers
SOURCE: archos 5 60gb won't charge
How old is your unit? Maybe your battery is dead The one good thing about having a Archos 7 is that you can change the battery easily. Have you backed up everything on your archos? I hate to say it but you might want to try repair , recovery or your last gasp format the unit.
Try using the tools/settings/customer assistance function first. I have not had good luck with tough problems using that function, you might have to do a hard reset.
Posted on Aug 24, 2009
  • 42 Answers
SOURCE: My archos wont connect to my computer
i had this problem. you have to use a high speed usb port (2.0 i think) which is normally in the back of your computer and then it should be detected
Posted on Sep 05, 2009
Battery not charging properly
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 10, 2012 | Sony Ericsson Xperia Arc S LT18i
I have Xperia X 10 mini from Sony Ericsson. I left it charging overnight as I do every night since I've got it. And today when I woke up, I took the phone and instead of it being fully charged and
Chances are your phone got too hot during the night and overcharged the Lithium Ion battery. If those batteries are exposed to too much heat then they won't have the battery life they used to have. You need to purchase a replacement battery or contact your wireless carrier to see about getting another one.
Jan 24, 2012 | Sony Ericsson XPERIA X10 Cell Phone
Just bought a usb cord charger for my nikon coolpix s203 and its been dead fir a couple of days and I wont turn on
You left your camera on for a couple of days? I'd think your batteries are completely drained. The S203 doesn't charge batteries via the USB port. Try charging the batteries overnight using the supplied MH-63 charger.
If that doesn't do it, please reply to this post and we'll go on from there.
May 13, 2011 | Nikon Cameras
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
My Archos 604 wifi only play a few minutes after charging.. I have used the dvr, usb and wall charger and nothing helps.. is my battery kaput? also since messing with it the touchscreen isn't working......
it must be the battery..While charging is pilot lamp lightning ?
To verify,just plug the USB cable to see if device battery charging circuit is working..Device should work normally..
If it does,either your battery is dead or its charger needs to be changed.
Kazim
Sep 13, 2009 | Archos 604 WiFi Digital Media Player
Archos 5 60gb won't charge
Aug 09, 2009 | Archos Internet Media Tablet MP3 Player
I have a 605 wifi and it sits in the charging platform. I cannot get it to turn on past the Archos titile page and then it seems to fade and fail like there is no power. It is only 8 months old. Is the...
Hi have you got your power supply plugged into the charging platform??, It would appear you have insufficient charge in the batteries on the 605.
If you have the USB lead plugged into the charging cradle this would normally ask you to select either charge or usb.
What does the CHG. light on top of the 605 do when you plug the unit into the cradle ?? (steady green-- charging. flashing green-- fully charged)
Dec 03, 2008 | Archos 605 WiFi Digital Media Player
C50 olympus power up
Is suspect the battery has been damaged Tell me more about the leaving in the USB port- this is not the normal way a battery is charged. Is it different for this model of camera?
Aug 14, 2007 | Olympus Camedia C-50 Zoom Digital Camera
Archos Internet Media Tablet MP3 Player Logo
181 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
