Element Electronics FLX1911B 19 in. LCD TV Logo
Posted on Nov 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Element tv has power but won't turn on - Element Electronics FLX1911B 19 in. LCD TV
Anonymous
Level 3:
  • Master 732 Answers
  • Posted on Nov 18, 2009
Anonymous
Master
Level 3:
Answers
732
Questions
Helped
297508
Points
2071
Lik2brew, Well here goes!! Your LCD panel, same as lcd panel in computer MONITOR, requires a little more than 120vac from the wall to create the cool, crisp, colorful images you see on the screen. It is my best GUESS, that your unit has a "FAILED" SMPS, or is "IN SHUTDOWN MODE" trying to save itself from having a catastrophic nonrecoverable event! e.g. sparks, smoke, fire. The SMART "switch-mode-power-supply" is designed to detect FAULTS with itself and other peripheral circuits. Your LCD TV is no different than the CLASSIC "BLACK-SCREEN of DEATH" that thousands of 14" to 32" LCD computer monitors suffer from!! Your set just has 2 more things to go wrong! A tuner, and audio processing circuits. While your waiting for the HOPS and BARLEY to ferment, surf over to YOUTUBE and view some of the longer video clips of typical "LCD monitor disassembly" and "LCD monitor repair" and find out what LCD owners do to fix them or to who they "farm out" the repair work to.!! If your screen had nice, bright, crisp, colorful images displayed on it just before the BSoD hit, then there is a good chance of effecting a lasting repair to the unit. If this was of some interest to you please rate on fixya. 12fixlouie
  • Marky Mark
    Marky Mark Jun 01, 2017
    Stop smoking crack.
Element tv was working fine now get a pink screen only. Turned tv off for 2 minutes and tv worked fine then shut off and now power light flashes from bright to very dim. Tv won't come on now ????¿?
Sounds like power supply has fried, take to TV repairman or since its an Element just buy a new one that is not an Element. Get a LCD, LG is good.
Element flat screen tv screen appears off when power is on
At this stage, try replacing ps Caps. Old elements had cap problems in ps area.
1helpful
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
My element tv won't turn on
check the cord wire( i think it is cut)
2answers
When i turn the tv on it comes up the main screen like,tv, hdmi,1 exc.then with in secounds it goes to a black screen it will not let medo anything unless i turn off and does the same thing i need help...
You have a power supply problem. Within about 32 seconds the picture drops out because the backlite transformers shutdown. Yoy will have to find a new power supply or have some one fix yours.
GE oven will bake but not broil
I trhink more than likely you have a faulty element, you need to test wether you have power to the element with a voltage tester or meter
Nov 22, 2008 • Ovens
Top Element Electronics Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
