Here is a picture of the wire connection for 24 volt. Compare to yours is it correct? If it is, I wish you listed make and model I could of sent you the right picture diagram of you motor. Use this picture as a starting point. Test the wires through the motor testing for 24 volts. Again if I knew make and model I could show you exactly were. Last if voltage is correct all the way through. The motor is the last thing to tear down. If the brushes or armeture is damaged in anyway, or manufactured wrong, it would lead to power loss.
I have a minn kota riptide 74 lb trolling motor. the plug on the trolling motor shorted out. i bought a new plug and it only has 3 pronges but the trolling motor has 4 wires and i can't get the right wires to work. which wires do you hook to plug.
