Netgear wireless-G router was working fine. now it says it is locked. how do I unlock it, password isn't working? It keeps saying not connected
1)The Default password for wireless-g is admin and the password itself is the word password both being lower case.
2)If the default password is not working or it is locked then the password might have change the password to something else.
3)To get the default access to the router web interface we have to hard reset the device but if we reset the device to the default setting's the internet connection will be terminated and the all the setting's has to be done from the beginning.
4)Following procedure will help you in hard resetting the device:-
a)You will find the very small/tiny circular pin hole on the rear panel of the device very close to the power.
b)Use the paper clip or a pin to reset the device and keep holding the reset button for at least 30-35s.
c)Then , While holding the paper clip take the power cable out from the device , wait for 10-15s and then plug the power cable back to the device while holding the paper clip.
d)Wait for another 10-15s and then release the paper clip.
e)Once we have all the lights back on to the device then take the power chord out and plug it back within 30s.
5)Once we follow the instructions the router will be reset to the default setting's and the internet connection will be terminated.
6)Open the IE page and in the address bar type the url:-http://www.routerlogin.com and then press enter key.
7)A small window will prompt up which will ask you to type the user name and password which will be
user name:-admin
password:-password
and then left click on log-in.
8)Once you will left click on log-in it will navigate you to the router's administrator page which will be netgear smart wizard page from where you can configure the router's setting's.
