Panasonic DMR-E75V DVD Player/VCR Logo
Posted on Nov 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic DMR-E75V Dubbing Problem
I'm trying to dub my homemade vhs tape to dvd and be able to play the dubbed dvd disk on my mac laptop. I'm able to dub from vhs to dvd but it only plays in the pansonic. It won't play on my laptop. I'm trying to figure out how to play the dubbed dvd on my laptop because I want to edit it. Any suggestions on how to solve this problem?
Anonymous
Level 2:
Champion:
  • Expert 208 Answers
  • Posted on Mar 18, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
208
Questions
0
Helped
61684
Points
488
You will need to finalise the disc in your DVD recorder before it will play on any other equipment
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
On the Panasonic DMR-E75V DVD Player / VCR Combo; I lost my manual; how do you dub (copy) the vhs to dvd?
You can enter the menu option on-screen - [FUNCTIONS] button, then, look for 'COPY' then select VHS as source DVD as destination.
Or you can download a .pdf copy of the manual ONLINE - it's free for this model.
http://service.us.panasonic.com/OPERMANPDF/DMRE75V.PDF - you can save this manual for future use.
27helpful
2answers
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
1helpful
2answers
VHS to DVD-R dubbs fine: but won't play on SONY DVD player.
Please finalize burned DVD to play in another dvd player.
I have a Panasonic DMR-ES30VEB. Video and DVD recorder. It won't play any shop bought Video's. No picture, No sound. Video's I have made myself I can watch. Picture and sound fine. When dubbing shop...
Are you playing it through the vhs mode. It will not play through the dvd mode via 'TJ' or dubbing as the dvd record function is macrovision protected
regards
snapper
3helpful
2answers
How To Burn a DVD from VHS tape
Insert the VHS tape. Do not press play. Insert a DVD RAM or DVD-R into the DVD side and press and hold DVD DUBBING, it should start playing the VHS immediately while recording on the DVD side.
Panasonic DMR E85H Shuts down when playing DVD or dubbing
the ic chip fixed mine tried to contact panasonic to give them negative feed back .its imposable
1helpful
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Panasonic DMR-EH50. Dubbing NTSC VCR tapes to HDD
That's normal with different region signals. Only a multiregion recorder/player combo will transfer properly
1helpful
Help w/ panasonic burner
I own one and it is a pain to work. Put in the disc and vhs tape and hit the bottom right button, I believe it says DVD and above it says dubbing. Hold it for a few seconds and the screen will come up and the system will do the rest recording from your VHS tape to the disc. You MUST finalize the disc after you are finished if you want to watch it in another DVD players if not it will only work on the Panasonic. Hope this helps. If not here is the site for the owners matual http://www.panasonic.com.au/support/downloads/file_type_results.cfm?fileTypeID=2&productCategoryID=54
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
