Question about Microsoft Office 2008 for Mac: Mac
I have been trying to get Microshaft word 2008 for Mac to start page numbers only on page 3. I have a title page, a table of contents, and then the body of my document. I have created a section at the bottom of the table of contents. Then in the footer, to the next section, I have tried to insert page numbers. BUT it routinely adds page numbers to the bottom of the first section as well. SO I have page 1 on the title page, page 2 on the table of contents; then I have page 1 on the first page and so on. How do I get page numbers, only on page 3 and beyond?
  • 864 Answers
1. Place cursor in each section in which you want hide the page number on the first page.
2. On the Insert menu, click Page Numbers.
3. Clear the "Show number on first page" check box.
You may have to create a separate section for your Table of Contents to suppress the page number on it.
Posted on Nov 18, 2009
SOURCE:
I need user manual for Targus laser pointer model AMP01US.
ManualsLib has the User Manual for the Targus AMP01US Wireless Multimedia Presenter with Trackball here: https://www.manualslib.com/products/Targus-Amp01us-7090628.html . You can download the manual from the Download button in the upper left corner of any page after the title/table of contents page.
I hope this helps.
Sep 02, 2018 | Targus Computers & Internet
I'm printing Microsoft Word 2008 for mac files to an HP2600n printer and the tables with shading that has any blue in it comes out black. Why? Why?
It's possible that the Cyan toner is low or depleted. If so, the printer will print the blue areas in black. This is a possible way to check:
1. Open your Applications folder and double click on "System Preferences."
2. When it opens, click on the printer icon with "Print & Scan" underneath it.
3. Click on the HP2600 printer on the left, then click "Options & Supplies"
4. Click on "Supply Levels." Check the Cyan toner cartridge. If it's low, then you'll have to buy and install a new one.
Here is a link to the HP cartridge page.
You'll have to consult the information that came with the printer on how to replace the cartridge.
Aug 14, 2012 | HP Color LaserJet 2600n Printer
File or directory corrupted and unreadable
The directory is like a "table of contents" in a printed textbook.
If a child's crayons have been used to overwrite those pages, making them unreadable, then the table of contents cannot be used to locate the starting page-number of a specific chapter. So, one must read through the whole textbook, page-by-page, looking & trying to recognize the start of a chapter, and then the end of the chapter.
Similarly, there exist "file-recovery" computer software programs that do such "linear" reading of the entire ZIP disk, and trying to reconstruct the "file-structure" that was recorded in the "disk-directory".
Search for "file scavenger" software, and give it a try.
Dec 08, 2009 | Computers & Internet
My document has a cover and a table of contents. I want page numbering with one to start on the third page. I did do the page break for the cover and the contents and was able to start the document on page...
There are two ways to do this. The first way SOMETIMES works. If you don't have luck, try the second method.
Method 1:
  • Delete the page break between the end of page 2 and page 3
  • Position your cursor at the start of page 3.
  • Click on Insert / Break / Next page
  • Select all the text form page 3 to the end of the document.
  • Click on Insert / Page numbers. UNCHECK "show number on first page"
  • Click on <Format>. Make sure "Start at" is selected and the value is "1". Select <OK>
  • Select <OK>
Method 2:
You need to work with the headers and footers. When you are done, you'll have two different footer sections that are NOT connected.
  • Add a "next page" section break as you did above.
  • Click on View / Header and Footer
  • On the Header and Footer toolbar, Click on the icon for "switch between header and footer"
  • page down to page 3. Click on the "link to previous" icon on the header and footer toolbar
For some reason I occasionally have to do this twice to get it to stick but eventually it should work. The key is to make sure you have two separate footer sections; the first section is page 1 and 2 without page numbers then the second section (starting with physical page 3) that has page numbers starting with page 1
Sep 10, 2009 | Microsoft Word 2003 for Students &...
New Epson RX595 won't print
Apparently the latest software doesn't work with Leopard 10.5.2. I uninstalled the Epson software and installed the earlier version [driver version 3.88] that come on the Installer CD with the printer. Printing now works.
May 18, 2008 | Epson RX595 Photo All-In-One Printer
HELP... unlock my router
1. From the "Setup" page, click Advanced
2. When the "Filters" page opens, click on the Wireless tab
3. Make sure all wireless computers are setup to the router, and are currently able to access the internet. Once this is done, click on the Active MAC Table button.
4. Move the "Wireless Active MAC Table" window and click on Edit MAC Filter Settings on the main window.
5. When the "Wireless Group MAC Table" opens, go to the task bar and click on the Wireless Active MAC Table so that window appears.
6. With the two windows side by side enter the MAC Addresses from the "Wireless Active MAC Table" window into the Wireless Group MAC Table.
Note: When you enter the MAC Addresses do not include the dashes/semi-colon, and do not click "Filter"
7. Click Apply then Continue in the "Wireless Group MAC Table" window.
8. Close the "Wireless Group MAC Table" window and the "Wireless Active MAC Table" window
9. On the Main window Enable the Station MAC Filter setting.
Apr 12, 2008 | Linksys Wireless-G WRT54G Router
Setting up Wireless Security ? BEFW11S4
Securing your wireless network is a simple process, which generally does not require a lot of time. Please follow these instructions to secure your wireless network. Accessing the Router 1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 2. When "Internet Explorer" opens type http://192.168.1.1into the "Address" bar and click on Go 3. The "Enter Network Password" window will appear. 4. Skip user name and type admin (admin is the default password) as the password, and click OK Setup Page Security Options When you arrive at the Setup page, you'll see the bulk of your wireless security features. There are three things you're going to want to set on this page: 1. SSID a) Delete linksys from the "SSID" field b) Input your own unique SSID. We general recommend something easy to remember, but secure enough to where people would not be able to guess it easily. Sometimes your best bet is to use your last name and add some numbers. a) Click Apply then Continue 1. SSID Broadcast (Firmware 1.42.7 and above only) a) Click No on the Allow "Broadcast" SSID to associate? b) Click Apply then Continue 2. WEP a) Click Mandatory for the "WEP" Option b) Click the WEP Key Settings button c) When the "Wep Key Settings" Window appears, change the option from 64 to 128* NOTE: 128 bit WEP may not work on non-Linksys products due to its lack of an IEEE standard d) Enter a passphrase** that is different from the SSID. Try to make it alphanumeric; instead of password, use password5532. Once the key has been Generated copy the key into a notepad document and copy that file onto a floppy. **NOTE: The passphrase will not work with non-Linksys products, so you will need to use the passphrase that you copied onto floppy. e) Click Apply then Continue f) Close the window g) Click Apply then Continue on the setup page. Setting up Station MAC Filter The Station MAC Filter option is a very good security feature that has been added to Firmware 1.42.7 and above. This option denies all wireless clients except those listed. To implement this feature please follow these instructions: 1. From the "Setup" page, click Advanced 2. When the "Filters" page opens, click on the Wireless tab 3. Make sure all wireless computers are setup to the router, and are currently able to access the internet. Once this is done, click on the Active MAC Table button. 4. Move the "Wireless Active MAC Table" window and click on Edit MAC Filter Settings on the main window. 5. When the "Wireless Group MAC Table" opens, go to the task bar and click on the Wireless Active MAC Table so that window appears. 6. With the two windows side by side enter the MAC Addresses from the "Wireless Active MAC Table" window into the Wireless Group MAC Table. - NOTE: When you enter the MAC Addresses do not include the dashes, and do not click "Filter" 7. Click Apply then Continue in the "Wireless Group MAC Table" window. 8. Close the "Wireless Group MAC Table" window and the "Wireless Active MAC Table" window 9. On the Main window Enable the Station MAC Filter setting.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
Microsoft Office 2008 for Mac: Mac Logo
330 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
