SOURCE: My Maytag Neptune Model MAH3000AWW starts to go
sounds like your control board is going out. when control board is replaced you want to replace wax motor as well
SOURCE: My Neptune washer model # MAH3000AWW has developed
It sounds like the bearings in the rear outer tub have gone out. This is caused from using powder soap. ( It also happens with liquid sometimes) This is a common problem with front load washers. This is a also a very costly fix. You have to replace the whole outer tub assembly. To get an exact cost just call your local service tech and tell them what your problem is and they can give an idea how much it will be.
SOURCE: maytag neptune mah3000aww spin problem
there are 2 wires going back to the board. They connect to a blue harness. Make sure their is continuity thru the harness. It connects to 3 out of balance swithches. Also check to see if lock light comes on.
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
