Samsung Galaxy S6: How to get voicemail (phone calls go direct to voicemail)
Hello.. 2 things we need to address here:
1. How to access voice mail account:
Access VM: Press 1:
Easy way to access your voice message system is to go to the dialer pad on your phone and press down on the "1" key until your voice messaging system announces
or you can dial your phone number to get to your voice mail
2. Change Call Setting, go to:
Dialer > (3 dots) Select Settings > Call > (scroll down) Select More Settings > Call Forwarding > Voice Call > then change to Always Forward (turn off)
Night service will only control if AA to answer (main greeting) or human, you!. If people enter extension and it goes straight to vmail then the user invoked that option (Feature 987) which is what you should do when you leave your office.
are u dialing ur voicemail by using direct dialing icon?
If so, u need to contact ur service provider and get the voicemail number , put that number in again. Enjoy direct dialing.
Hi, on the phone where this is happening , with the handset down dial 600 to clear forwarding, then dial 602 followed by your voice mail number, this can be found by pressing your VM key, the number which flashes on the screen is the one you use. I have put 1 of the videos from http://www.abbeytelecom.com which will help,
Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
I have seen the same problem with some users (I look after the PABX) so I just go into the maintenance console and set up the foreward to the default voice mail number. Or you can try the following:
CALL FORWARDING HANDSET
1.Press the Speaker Phone Key on your handset
2.Then Press the FWD/DND Key
3.Then select the Forward type you desire -
Key 2 - Immediate
Key 5 - Busy/No Answer
4.Then dial the internal extension number (eg.444) or voicemail pilot (201)
4a.If forwarding to external number dial 0 then dial outside telephone number
5.Dial # then press the Speaker Phone key
Taking out the battery for a few minutes and then putting it back in and turning it back on usually fixes the problem for me. Once I had to take out and reseat the SIM chip also before putting the battery back in.
hi there penny yes i was about to say dial 121 thatll take you straight to your message inbox voicemail box or ring your servic provider and get them to go through step by step with your voicemail settings hope this helps and if you have time please rate me
thanks again
Use the super key again to program a speed dial key that dials the voicemails number. Instead of selecting 'clear' slect "change" and type in the number. To find the number of the voicemail, go to another phone and press their voicemail key and watch the display. It may briefly display the voicemial group number. You also can dial the voicemail number without the use of a button on your phone. But, you have to know the voicemail group number to dail it. Sorry i dont know the number to tell you, it could be anything that the installer decided to make it.
