I have a Norstar CICS system, and the handset for the System Coordinator is missing. I'm guessing our password is the default, but how can I get into the system when none of the other handsets allow me to use System Coordinator features?
Thanks for your reply. I think I have the right kind of handsets around here, but being an entire novice with phone systems, my perception is that the actual handset that was x222 in this case was the one that was allowed to enter System Coordinator features, and I don't know how to give another handset that right. Any thoughts?Carl
You can't post conmments that contain an email address.
What type of System is it? Norstar systems default to 2 lines if they loose memory (which isn't supposed to happen). That being said, I recently had had to replace an old Norstar 616 that would not hold memory after a power outage. I took the KSU apart and could not find any internal battery to replace. I'm guessing some kind of capacitor ?? In any case the system had to be replaced. Bill C. www.dyna-tech.us We also do remote programming on Norstar CICS ans MICS.
Hi, what do you want to change? What feature is programmed on the button?
"EACH OF THESE CODES ARE PRECEDED WITH THE ""FEATURE" " KEY"
**CONFIG NORSTAR CONFIGURATION PROGRAMMING (INSTALLER) **SCPLUS NORSTAR SYSTEM COORDINATOR PLUS PROGRAMMING (CICS AND ICS 2.0+) **ADMIN NORSTAR ADMINISTRATIVE PROGRAMMING (SYS Coordinator) **BASIC NORSTAR BASIC PROGRAMMING (CICS & ICS S.0+) **SET NORSTAR SET PROFILE **LINE NORSTAR LINE PROFILE **USER NORSTAR USER PREFERENCES (CICS & ISC 2.0+) **TIME NORSTAR TIME AND DATE (CICS & ICS 2.0+) *0 BUTTON INQUIRY *1 FEATURE KEY EXTERNAL AUTODIAL *2 FEATURE KEY INTERNAL AUTODIAL *3 FEATURE KEY PROGRAMMING *4 PERSONNEL SPEED DIAL *501 SELECT ENGLISH *502 SELECT FRENCH *503 SELECT SPANISH *6 RING TYPE *7 DISPLAY CONTRAST ADJUST *80 RING VOLUME ADJUST *81 MOVE LINE KEYS *82 DIAL MODES *831 AA ON/OFF (CICS) *832 CCR ON/OFF (CICS) *833 AA/CCR RECORDING MAINTENANCE (CICS) *84 AUTO LOG OPTIONS *85 CALL LOG PASSWORD *89 PROGRAMMED RELEASE *9 RUN/STOP 0 SYSTEM SPEED DIAL 1 SEND MESSAGE #1 SEND MESSAGE CANCEL 2 RING AGAIN #2 RING AGAIN CANCEL 3 CONFERENCE / TRANSFER #3 CONFERENCE SPLIT 4 CALL FORWARD #4 CALL FORWARD CANCEL 5 LAST NUMBER REDIAL 60 PAGE GENERAL 61X PAGE INTERNAL ZONE (1-6) 62 PAGE EXTERNAL 63X PAGE INTERNAL ZONE (1-6) PLUS EXTERNAL 64 LINE POOLS 65 MESSAGE REPLY #65 MESSAGE REPLY CANCEL 66 VOICE CALL 67 SAVED NUMBER 68 RESTRICTION /COS OVERRIDE 69 PRIORITY CALL 70 CALL TRANSFER (BLIND) 71 LINK (HOOK FLASH) 72 TIMED RELEASE 74 CALL PARK 75 GROUP CALL PICKUP 76 DIRECTED CALL PICKUP 77 CALL DURATION TIMER 78 PAUSE 79 EXCLUSIVE HOLD 800 TRUNK ANSWER 801 CALL QUEUING 802 GROUP LISTENING 803 SHOW TIME 804 WAIT FOR DIAL TONE 805 TEST SETS (2.0) 806 HIDE DISPLAY 808 LONG TONES 810 MAKE BUSY 811 CALL INFORMATION 812 ENTER CALL LOG 813 LOG IT 815 AUTO BUMPING 817 IRAD TRANSFER (CICS ONLY) 819 OUTGOING NAME AND NUMBER BLOCKING (4.1) #819 CANCEL OUTGOING NAME AND NUMBER BLOCKING 82 CAMP ON 83 PRIVACY CONTROL 84 LINE REDIRECTON #84 CANCEL LINE REDIRECTION 85 DO NOT DISTURB #85 CANCEL DO NOT DISTURB 86 BACK GROUND MUSIC #86 CANCEL BACKGROUND MUSIC 87 "SERVICE MODES (DR-3,4,5)" #87 CANCEL SERVICE MODES 870 SHOW SERVICE MODES (CICS) 871 EXTENDED RINGING (ICS) #871 CANCEL EXTENDED RINGING 872 ALTERNATIVE RESTRICTIONS #872 CANCEL ALTERNATIVE RESTRICTIONS 873 ALTERNATIVE ROUTING #873 CANCEL ALTERNATIVE ROUTING 88 VOICE CALL DENY #88 CANCEL VOICE CALL DENY
FEATURE 900 CODES ARE USED FOR OPTIONAL EQUIPMENT SUCH AS: "VOICE MAIL, ACD, DIAL BY NAME, DOOR PHONE, ETC." THE FOLLOWING ARE SOME COMMON USAGES: 9** "RAD PROGRAMMING (RAD 2, FASTRAD)" 9*0 RAD TRANSFER (ALL BUT CICS IRAD'S) 9*1 CHECK FEATURE CODES FOR VOICE MAIL 9*2 SMDR Admin 9*3 LOGGER TIME STAMP 9*3 VMI Codes(this was on an 8x24, came up on this code rather than F9*9) 9*4 NORSTAR DOOR PHONE PROGRAMMING 9*5 FLASH LOW RANGE CHECK FEATURE CODES 9*7 ACD ADMIN MAINTENANCE SESSION 9*9 VOICE MAIL INTERFACE (VMI) CODES 900 SMDR,enter an account number to be logged with the call 901 ACD LOGIN 901 VMI Admin 902 ACD UNAVAILABLE 903 VOICE MAIL HIGH/LOW RANGE SELECTION (DISABLED AFTER USE) 903 ACD CANCEL WRAP 904 ACD HELP 904 FLASH ACD LOW RANGE LOGIN/OUT 905 ACD CATEGORIZE 905 FLASH LOW RANGE DN IDENTIFIER 906 ACD RECORD CALL 906 FLASH LOW RANGE VM TRANSFER 907 FLASH LOW RANGE VM INTERRUPT 908 STAR TEXT (OBSOLETE) 908 FLASH ACD LOW RANGE BUSY MODE 909 ACD ANN. MAINTENANCE 909 FLASH ACD LOW RANGE QUEUE STATUS 910 FLASH LOW RANGE LEAVE MESSAGE 911 FLASH LOW RANGE OPEN MAILBOX 912 FLASH LOW RANGE OPERATOR CONTROL 913 ACD CALLS QUEUED 913 FLASH LOW RANGE SYSTEM ADMIN LOGIN 915 NORSTAR VOICE MAIL 2ND LEVEL ACCESS (PSWD=ACCESS2) 920 ACD ADMIN SESSION 921 ACD ROUTING SESSION DAY/NIGHT 922 ACD ADMIN STATISTICS SESSION 923 ACD GROUP STATISTICS SESSION 960 DIAL BY NAME (CINTECH NSVM OPTION) 961 DIAL BY NAME ADMIN (PSWD=1234) 980 VM SEND MSG TO ANOTHER MAILBOX 981 VM LOG INT MAILBOX 982 VM OPERATOR STATUS(PSWD=OPERATOR(67372867)) 983 VM ADMIN PROGRAMMING (PSWD=1020000) 983 VM SOFTWARE LEVEL(LOGIN THEN OPTION 9) 984 VM TIME AND DATE(STARTALK Pswd=1020000) 984 AUTO FOREWARD TO VMAIL(NSVM4.0) 984 FLASH ACD LOGIN/OUT 985 "VOICE MAIL DN INQUIRY(RESET VM ADMIN PSWD 9,73738767793)" 986 VOICE MAIL TRANSFER 987 VOICE MAIL INTERRUPT 988 VOICE ACTIVATED NAME DIALING (NSVM 4.0) 988 FLASH ACD BUSY MODE 989 RECORD CALL (NSVM 4.0) 989 FLASH ACD QUEUE STATUS
You have lost system programming. Unless you are well versed in getting into your system with the installer password, you need to call a Nortel service tech. The older systems have a battery backing up the memory and when it dies, your system crashes. It's really obvious, because it goes back to the default of only 2 lines working and all the buttons become defaulted.
Entire systm programming is beyond the scope of this forum. I do have a CICS programming sequence on my website http://www.public.carl.airpost.net/Nortel/CICS_Programming.pdf
It would be unlikely that your system is a CICS, but this is an idea of where the programs are and what level you need to access them.
Pretending that you have the right System Admin code and are using a CICS, here's the chart. If you don't have the right password, you won't see the prompt.
The feature codes will not help you troubleshoot the system at all. But here you go:
"EACH OF THESE CODES ARE PRECEEDED WITH THE ""FEATURE" " KEY"
What do you want to change? What feature is programmed on the button?
Press "Feature 985" - this will show the voicemail extension. Dial "9" and it will prompt you for a password. Using the dialpad, dial "RESETSMPSWD". This will change it back to the default of "0000".
ON NORTEL DO A FEATURE 983 PASSWORD IS GOING TO BE 120000 AND THAT WILL PROMPT YOU THRU RESETING THE PASSWORD IF THAT DOES NOT WORK DO A FEATURE 985 PRESS 9THEN TYPE IN (RESET SM ) THEN TYPE IN (PSWD) AND IT WILL GO BACK TO DEFAULT . PS THE SM STANDS FOR SYSTEM MANAGER
Carl
