Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
Why does Scanner Drive keep showing up on my computer when I turn it on, and I did not put it there? TKB
Make this massge the disk is write- proteced remove the protection or use another disk
Posted on Nov 17, 2009
SOURCE:
Check turns
You should be getting a P code from an OBD2 scanner. It sounds like a vacuum leak though.
Apr 02, 2014 | 1998 Honda Accord
Codigo de programacion taika modelo tkb-ac
Tengo un control remoto marca taika TKB-AC y Busco el codigo de programacion para un minisplit marca LG
Traductor: I have a remote control taika brand TKB-AC and the programming code looking for minisplit brand LG
Nov 10, 2013 | Televison & Video
I tried installing the HP scanjet 5590 scanner on a pC but it jut shows that it is installing and stays there forever. Anyone knows ow to solve this problem? PLS help-thanks in advance.
1) HOW MUCH COMPUTER MEMORY DDR MEMORY DOES YOUR COMPUTER HAVE INSTALLED?
2) HOW MUCH FREE SPACE IS ON YOU CURRECT HARD DRIVE?
3) TURN OFF YOUR ANTI-VIRUS SOFTWARE AND SPYWARE DETECTORS THEN DO THE FOLLWOING:
A) UNPLUG SCANNER FROM COMPUTER
B) MAKE SURE THE ANTI-VIRUS AND SPYWARE DETECTION SOFTWARE IS TURNED OFF FOR THIS INSTALL.
C) INSTALL SOFTWARE FROM ORIGINAL CD/DVD
D) ATTACH SCANNER AND ALLOW IT TO DETECT THE SCANNER AND ALLOW IT TO SEARCH FOR BEST DRIVER.
E) IF THIS DOES NOT WORK THEN EMAIL ME AT RAFURMANEKJR@HOTMAIL.COM
Nov 25, 2010 | HP Scanjet 5590 Flatbed Scanner
Hyundai tiburon 03 2.7cyl
have light turned off with scanner, or drive it a few miles to see if it goes off. just because the sensors have been changed the pcm thinks there is still a problem and keeps light on. turn off with scanner.
Apr 26, 2010 | 2003 Hyundai Tiburon
It won't scan. I took the cover off and it the drive wheels are turning, but the scanner doesn't move. The box that shows % scanned just stays at 0%. It's a conoscann 4400f
turn off the scanner, disconnect and reconnect it from the computer. if it still doesnt scan, reinstall the scanner driver(make sure you install the latest version) then restart your computer. hope it'll help. good day. =)
Dec 22, 2009 | Office Equipment & Supplies
Error
I had/have the same printer and the same problem. I am running Windows XP.
Go to the "Control Panel.
Select "Scanner and Cameras"
You should see your device listed here. If not then add it.
Select your device and you will see "Welcome to the Scanner and Camera Wizard".
Select "next" the following three times.
It will then scan the desktop.
Select "Next" and then finish.
The red error light should be gone.
I suggest ignoring the red light unless it just drives you nuts. You may have to run this everytime you turn your computer and printer on. Some reason the scanner is not linking with windows and you have to introduce them everytime.
Keep the printer.
Nov 24, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Scanner Failure
The only thing I can surgest is that you check installed programs I found that the 750 is very fussy about being the only kid on the block. Maybe worth trying a commercial program that says it will remove "junk" from your hard drive
Aug 24, 2008 | HP PSC 750 All-In-One InkJet Printer
Artec e +48u scanner
quite possible the scanner motor finnaly gave out but lets look at other things first
try connecting to another usb port on comp before that completly take out all of the scanners drivers and programs this could be a simple file corrupt
i know you tried this but sometimes putting a new driver over old driver doesnt usually change the old drivers properties this is when you completly take out all drivers and software and start from scratch for this scanner
May 11, 2008 | Office Equipment & Supplies
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
90 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
Paras Waiba
Level 1 Expert
Falling star
John Lavis
John Lavis
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
