Pyramid - PS21KX  20 Amp Power Supply Car Audio Amplifier Logo
Dean Dishman Posted on Jan 10, 2008
Pyramid - PS21KX 20 Amp Powersupply overload
I got this from a friend and the transistors on the back were bad so I replaced them now when it powers up i get 12 volts then it dropsto 2.5 or so in a matter of 5 to 10 seconds and the overload light comes on what is causing this???I have a schematic but it says to refer to owners manual for the light but I dont have one.Please let me know ...Thank you
  • 1 more comment
  • Anonymous May 19, 2008
    I have a simular problem with low voltage on the PS-21 KX 12V 20A DC power supply. I think I might be able to troubleshoot the problem but I don't have a schematic diagram. Can someone e-mail a copy to me. Thanks
    Len VE2JG
  • Anonymous Jul 22, 2008
    I have a pyramid phase III 25 amp supply. When I use 15 watts or less my supply works o.k., but when I go to 50 watts the voltage drops from 14.8 to 9.2 volts. Also, 2 of the pass transistors do not heat up. I have no schematic, sure would appreciate a copy or a solution. Thanks, david
  • jpowell6012 Aug 26, 2008
    i am trying to run my kenwood radio (ham radio) on this supply but get no sound but when i hook it up in my car the radio works perfect
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 26, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16498
Points
Http://www.pyramidcaraudio.com/manuals/PS21KX.pdf
  • Anonymous Feb 26, 2012
    here is the manual guys. it has schematic inside. enjoy.
  • Dean Dishman Feb 06, 2014
    thanks
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Mar 14, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2797
Points
5
The problem I have had with a PS-20 is a blown capacitor. Hooked to a radio, would allow radio to receive fine, but when trying to transmit, amperage would bottom out. Behind the transformer is a large circuit board. UNPLUG POWER SUPPLY, remove cover, Undo the two nuts, flip board over, and gently rock the 4700uf capacitors side to side. If they move more than 1/16th of an inch, chances are they are blown. Remove/replace and should be good to go...
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2034
Points
Can someone send a copy of the Pyramid PS21-KX power supply (schematic diagram) so I can troubleshoot major problems. Thank you.
Len [email protected]
A
Anonymous
There are obviously more bad parts inside that need replacing.
Cooling fan
Cool.
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
Linking 2 amps together
Say that three times real fast.
I am getting 240volt accross the ground and neutral at the output
You're getting 240 volts from a pyramid amp?
Ps 52 kx power supply will not hold load
thank you for your help . I have already fixed the power supply I double checked the transisters and found three bad so I replaced all the power transisters and it is fine . thanks again bob
Pyramid ps-36kx
Generally, the fuse only blows when the rectifiers fail. In other Pyramid supplies, they use a square, 4 terminal bridge rectifier. They probably use the same thing in your supply.
Let me know if you have any other questions.
2answers
PS36K power supply overload problem
Most of Pyramid's supplies are based on the LM723 voltage regulator. The DATASHEET should tell you most of what you'll need to know to repair it. THIS is the schematic diagram.
If the output voltage drives the voltmeter to the end of the scale, it likely has one or more shorted power transistors.
Top Pyramid Car Audio & Video Experts
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
xxxxxx xxx
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
