Possible that the grinding noise comes from the drum, irregular movement or broken paddles. You can try and attempt only if equipped with a fundamental understanding of the working . I shall give you some tips to this click 1..: Washing Machine
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Sounds like the transmission seal had failed sometime back and has leaked the lubricant causing the transmission to overheat and now possibly seizing the gears, if this is the case the transmission will have to be replaced. Depending on the age of the washer, (5 years or less) you should contact Maytag to see if they will compensate you by way of furnishing the new transmission for free, but you will be responseable for the labor charge from a tech to do the replacement.
If they will not cover the part, you will probably be better off to replace the washer than to invest in the cost of a new trans and labor.
Good Luck !
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Most noises
