SOURCE: water leaks from weap hole in bottom of the plastic housing
The Maytag's have always had problems with those front door boots leaking and not draining thus leaving a bad mildew smell. What the problem probably is is that the hose that connects to the weap hole is cracked and needs replacing. I would suggest just replacing the entire boot along with the hose. The boot is a pain to replace though, it might take a tech to get it done for you. Let me know if you have any other questions and let me know if this information was helpful. Good luck.
SOURCE: washer leaks from bottom during rinse cycle
Take the cover off the back, and look up, next to where you put the soap in, when it's filling/rinsing. There is (like) a (white) plastic valve body, and look to see if water is dripping out of it. I haven't figured out a solution to that yet, other than to replace it.
Also check the boot, coming off the pump. You could have a bad/dry boot, or a loose hose clamp.
SOURCE: Hole Rubbed in Bottom Door - Leaks Through Front
If you can get to it you can use an epoxy made for metal or something like jb weld to patch the holes.
