Bosch 24 in. PIE675T01E Electric Cooktop Logo
Posted on Nov 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want some advice in how to clean my ceramic cooktop properly. I've been using a cloth and cleaning sprays because I dont want to scratch the surface but the stains are getting worse and worse. What products can I use? What is the best way to clean my stove?
John Riley
Level 3:
  • Master 441 Answers
  • Posted on Nov 17, 2009
John Riley
Master
Level 3:
Answers
441
Questions
Helped
138558
Points
1344
Look for Cerama Bryte, its a cream you put on, let sit and then scub off, works great
  • John Riley Nov 17, 2009
    look for Cerama Bryte, its a cream you put on, let sit and then scub off, works great
We have a CCE3401 Jenn-Aire Ceramic Cooktop. I was making jelly this week when I had a bad boil over. We used recommended products to clean up. It has left a black smooth spot above front left range...
Sorry to read about your problem, I hope this helps you out.
try using an oven cleaner spray... let the range heat up a little..then spray oven cleaner
a new glass top will cost over $600.00 just for the glass.
I have tried to help you. Please help me by vote/rate the response. Thanks If you live in the Denver Area. I can help you out.
tip
Best way to Fix Scratches on Your Radiant Smooth top Cooktop
Cooktops are in many homes and are a preferred kitchen appliance to many home owners. The Cook in the kitchen can appreciate the stylish look of a sleek radiant smooth top Cooktop . Many invest top dollar to have stainless steel appliances including the following: Refrigerator, Dishwasher and Compactor. Moreover, having a sharp looking Cooktop addition only compliments the style and design of any high end kitchen. Maintainence and care of such an essential attractive appliance such as a cooktop is important.
Here is the best way to fix scratches on your Radiant Smooth top Cooktop:
Step 1 - Prepare your Cooktop by cleaning the surface*Make sure the surface is cooled* Use a damp rag first and sweep of crumbs and food stuff. Use your favorite cleaner and rinse completely. Careful not to get moisture around knobs or switches. Dry off surface.
Step 2 -- Work on the scratch area
Run the sharp edge of a razor over the scratch around 3x and this will aid in smoothing out any raised ruff edges. Apply gentle pressure to the cooktop scratch area.
Step 3 - Apply A Cooktop Cleaner
Use a few drops of cooktop cleaner to the scratch area. Use a sponge to rub in cleaner. Use circular motions to allow scratch to absorb product. Run the razor edge over scratch again making sure not to apply to much pressure.
Step 4 -- Clean Cooktop surface again and remove cleaning product
Rise off cleaner and dry with a dry paper towel. Inspect scratch to test results. Repeat step 3 until you have desired results.
Special Note* Their are many ceramic cleaning products to choose from and many claim to be the best on the market. Be sure to choose one that has good reviews and then test the results. Special attention must be given to all radiant smooth top cooktops. Be sure to use only cookware that is recommend by the manufacturer. And be sure to clean spills as soon the cooktop is cooled to keep the appliance looking well. Deep scratches or pits cannot be removed or buffed out and may lead to a cracked cooktop.
How do i clean my cooktop on a whirlpool 465
Light Cleaning
  • Clean your CERAN cooktop after every use. To remove simple spills, wait for the surface to cool before beginning the cleaning process. Pour a small amount of cleaning cream on a damp paper towel and wipe the cooktop surface until the soil and cream are no longer visible. The cleaning cream will leave a protective finish, which will preclude scratches and other types of damage.
  • Heavy Cleaning
  • Wear a heavy oven mitt to remove burnt foods or liquids while the cooktop is still warm. Use the metal razor scraper to remove the substances that are stuck to the cooktop surface. Once the cooktop has cooled, use a damp paper towel to spread a small amount of cleaning cream over the entire cooktop surface and wipe it thoroughly until the cream is no longer visible. Rinse the cooktop with water and dry with a clean paper towel.
  • Cleaning Melted Substances
  • Remove melted plastic, foil or other kitchen products immediately using the metal razor scraper. Spills containing sugar, such as ketchup, tomato sauce, syrup or pudding, must also be removed with the metal scraper at once. It is best to remove these substances while the burner is still hot. Once the melted substance has been removed and the cooktop has cooled, use a damp paper towel and cleaning cream to complete the cleaning process. To protect your hands, remember to wear a thick oven mitt when cleaning the hot cooktop.
  • Tips
  • Scratch marks resulting from daily use will not interfere with the performance of your cooktop. Pots and pans with flat bottoms and those that cover the entire burner surface are recommended for use on your CERAN cooktop.
  • Warnings
  • Spills containing sugar may permanently damage your cooktop unless the substance is removed immediately. Use only the recommended cleaning products on your CERAN cooktop to protect it from damage. Do not use scouring pads, plastic coated sponges or abrasive products of any type. Do not use oven spray or any other type of cleaner containing ammonia or chlorine. Clean all spills thoroughly before using your cooktop again.
  • 0helpful
    Scratches on New Wolf Gas Cooktop
    The good news is you have a great product! You just need technique and the "Green" cleaner DeBruce Polish. Use DeBruce Polish and a cloth for clean ups. DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. We buy Debruce Polish at debrucepolish.com
    • Firstly clean with DeBruce Polish to clarify area.
    • you may have to "re-grain" those finely scratched areas.
    • Blend or "scratch out" the misdirection scratch's with new "controlled" scratching, useing a 3M scotch brite #7447 you get at auto parts store (Nappa). Use medium very firm pressure.
    • -Re-clean with DeBruce Polish. Touch ups are now a breeze.
    WHAT DO I USE TO CLEAN AN ELECTRIC JENN-AIR CERAMIC COOKTOP; THE BURNT FOOD BUILDUP.
    a good product is CERAMABRYTE. it is designed for ceramic cooktops and is a white lotion type cleaner. if there is a lot of burned buildup you may also need to purchase a special scraper with a blade in it. but make sure you smear the cleanser on FIRST or you will scratch the surface.
    2answers
    Scratched cooktop
    as far as i know its normal to have an scratched in glass ceramic hob defend how long to use or many times of use.do u think is same usage? its normal defend on usage.
    Viking Designer Series gas cooktop not cleaning well
    I'm sorry to say that there is not a wonder solution for this. You try laying a damp cloth on the aluminum part to try and allow the moisture to soak in the clean it off.
    Don't use anything abrasive as the aluminum will scratch.
    1helpful
    3answers
    Cleaning glass cooktop
    Hi, Any good glass/ceramic cooktop cleaner will do the job. Any grease spots or burned food spots can be scraped off with a razor scraper ( just keep it flat ) Use a couple of paper towels and put a dime sized drop of the cleaner on each burner and with a circular motion buff the top like you would wax a car, when cleaned up, flip the towels over and buff to a shine. I don't endorse any products but there are some that contain everything you need, cleaner , scraper, cloth like Ceramabrite. They can be found at most grocery, diy and some hardware stores. Good Luck!
    Top Bosch Cooktops Experts
    Paul Carew
    Jay Finke
    Jay Finke
    ADMIN Andrew
    ADMIN Andrew
    Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
