Question about Boss Micro BR Digital Recorder
I bought a used BR 532 Boss recorder - can't get a
I bought a used BR 532 Boss digital recorder - can't get a signal out - not on headphones or even optical line out. Was working at time of purchase - can't figure out the problem. Followed manual's instructions, etc - no luck.
    New Friend:
I get an unformatted come on the screen on my Boss BR 532 when I swith on, and also when pressing record, although I can get drum machine to work and guitar go through it ok but no recording Hmmmm Erggg
Posted on Feb 14, 2011
6ya staff
SOURCE:
Hi, I have a boss BR 600 and when i insert any card it checks the card and then says ' card not supported'. I t used o work fine. However i have noticed that 2 pins seem to be missing inside t
I have the exact same problem. All my flash cards worked fine, and all of the sudden, none work. Not even the one that came with it. I am still trying to fine the reason. I bought it eight years ago, that might be it.
Jan 30, 2013 | Roland BOSS BR 600 8 track portable...
Bought a new BR-800 Digital Recorder and I can't play the demo song on it. I have followed all directions, however am still not able to play demo song or even find it in the menu. Can someone hel
Remove power supply or battery for 5 minutes. Apply power while holding the on switch in, this usually resets most electronic devices to their factory default condition. Then look again.
Sep 03, 2012 | Roland Boss BR-800 Digital Recorder
How do i factory reset Boss Micro BR Digital Recorder
I know how to set it back to factory boss micro br.
Mar 18, 2012 | Boss Micro BR Digital Recorder
Boss br-600 unsupported card
Feb 12, 2012 | Roland BOSS BR 600 8 track portable...
I can't hear anything from my boss micro br without headphones....help!
I asssume you have ti connected to a mixer/amplifier as you have to have some sort of sound reproduction system connected. If you are going through a computer, you have the computer settings set improperly.
Sep 22, 2011 | Boss Micro BR Digital Recorder
Does the Micro-Br have any inbuilt speaker to hear the music etc
No you will have to connect it to an amp or plug headphones into the output jack socket
Feb 09, 2011 | Boss Micro BR Digital Recorder
BR 8 headphone jack
This may also sound stupid but; have you tried a different set of headphones? If you have never used the headphone jack there might be a chance that the contacts inside the jack are dirty from airborn pollutants such as cigarette smoke or cooking smoke. Another good example is if you have a flute or silverware laying around in the open , they will tarnish from the sulfur dioxide in the air. Try spraying a very small squirt of contact cleaner on a stereo plug and plugging and unplugging it into the jack. Make sure you do this with the power turned off. If that doesn't work, do it to the jack itself. Only use a very small amount. If that doesn't work you may have a bad solder joint in the connections to the jack or a circuitry problem. The jacks sometimes a have a built in switching circuit to defeat the signal when phones are plugged in and sometimes the jack fails. Hope this gives you some ideas.
Oct 30, 2009 | Boss Micro BR Digital Recorder
What do I need to burn a cd from my pc with the br 1180
This Is real simple grab a cable that goes from rca jacks to a headphone jack then plug the rca jacks into the br-1180's audio out jack and then plug the other end into your computers mic port.
Download Audacity From www.Audacity.com and then use it to capture you audio and then you can burn that when complete.
Its real simple I do it all the time even though I have the br-1180cd the cd burner burns real quiet so I don't use it. The cable can be bought at radio shack, best buy, wal-mart and I have even seen them at 99 cent only stores.
If you have more question let me know This Is my main unit so I know a lot about it.
Sincerely,
Michael Scott
Apr 29, 2009 | Boss Micro BR Digital Recorder
Boss Micro BR Digital Recorder Logo
440 people viewed this question
Top Boss Music Experts
Michial Gueffroy
lorenzo carolus
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Boss Music Expert? Answer questions, earn points and help others
