Daewoo DWD-F1011 IE error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code IE. Any idea what that might be?
replace the water shutoff solenoid valve assembly
in the mean time when the machine is full turn the tap off
change the hot water hose over to the cold water tap and use the hot water solenoid button
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
I have DAEWOO Washing machine DWD F1011. Whithin few years water started leaking through the drive shaft and ball bearing damaged. I need service manual for how to change the ball bearing or is there any repairer in Heliopolis, Cairo area?
If this machine is like other of its type then you may find the manual taped to the inside of the machine near the bottom side panel. open the bottom access panel (3 screws on bottom front lip) and look for it as it will have the codes. near where the filter is . while you were down there cleaning the filter did you check that the pump impellers move freely and were not clogged with any debris.
if this is a fridgidaire washer, I guess it's a clogged coin catcher. You have remove the front access panel and clean it out. I am working on that now.
