The blue Fn key which is used to make the other keys with blue functions work is locked on. To type I have to hold down the fn key and only get lowercase letters. I can not get capital letters using this method. If I don't hold down the blue Fn key I just get the limited blue functions from my keyboard.
Hit "FN" and the "NUM Lock" key together to unlock it.
I believe thats the combination.
Let me know.
Or, try holding the FN key for a few seconds. It varies of different models.
Fn+ NumLk solved this issue.. thanks Brian
Thanks Brian nja yam uyi life saver
Gr8 issue resolved
resolved
10 years late. now 12.
what a revelation..
I had the same problem and solved mine by hitting NumLk key only. I have a business toughbook, CF-W7
NumLk key only - that's the solution. Thank YOU! :)
Thanks that work for me also on Panasonic CF53
Thank you that worked for me too.
fn locked
I have same problem, I tried everything and still i can not make it work.
Same problem...numlk didn't solve it
KEYBOARD IS LOCKED USING BLUE FN NUMBERS SO WHEN I PRESS U, 4 COMES UP. PRESS I GIVES ME 3. HOW DO I GET BACK TO NORMAL KEYBOARD COMMANDS?
Just had the same problem with the FN key. Works perfectly now after pressing the FN and NUMLOCK together as suggested.
THANKS!!!!!
NUM LK KEY ONLY FIXED MINE TOO. THANKS TACHYON12!
turn on function keys without holding fn key
i have a problem about my fn+f1 functions key
Gr8 issue resolved
