Computers & Internet Logo
Posted on Nov 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does a hl-dt-st dvdram gma-4082n write to dvds? I
Does a hl-dt-st dvdram gma-4082n write to dvds? I know I can write to cds, but want to write a movie to a dvd... Thanks
Lee Hodgson
Level 3:
  • HP Master 4,810 Answers
  • Posted on Nov 16, 2009
Lee Hodgson
HP Master
Level 3:
Answers
4810
Questions
Helped
1782742
Points
15941
Yes, the DVDRAM will write to both CD's and DVD's. It supports single and dual layered DVD's.
Regards.
1helpful
HL-DT-ST DVDRAM GMA-4082N ATA DRIVER DEVICE Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) My cd/dvd drive stopped working. it says that the...
backup whatever information you have and run the system recovery through the disks you received when you purchased the computer. If you can perform the recovery then you know the hardware is fine and that you were experiencing software corruption.
2answers
GMA 4082n device driver not working properly code 39
The dvd does not need driver, you need to reinstall Windows.
HL-DT-ST DVDRAM GMA-4082N. Can not write to DVD
The DVD -R +R means that you can read these types of DVDs that have been created elsewhere, it doesn't mean you can write to your DVD under the format of -R or +R. The CD is a CDRW which means you can read and write to CDs.
I don't think that a factory Satellite P100 has the ability to write to either DVD -R or +R, but to only CDs. I have a P200 that has a DVD -R +R/CDRW and it can't write DVDs. These DVDs you put in are for read only. My Toshiba A215 can but it's a DVDRW/CDRW.
1helpful
LG HL-DT-ST DVDRAM GMA-4082N stopped reading some dvds
I also have had the same problem with my DVD drive. I Downloaded the new updates from the Lg.com website and Walaaaaaaa!!!!!!!! the problem has been Solved. Do the same for your dvd drive and you also can get your problem solved..........
Toshiba Satellite pro hl-dt-st dvdram gma-4082n
this is due to the fault of the device you should replace it
1helpful
check whether the device is detecting properly on bios or not
http://support.microsoft.com/kb/314060
Try this article...............hope it should work otherwise would suggest something lese as well......All the best....TC
1helpful
Thank you for using Fixya.com and glad to hear to got your monies worth.
Regarrds,
Worldvet
2answers
Go back to the device in device manager, right click on it and select properties, then under the driver tab click on "Roll back driver" button and see if that does the trick.
3answers
goto program defaults/media player/disc insertion= and choose the options you require. Or goto computer-cd/dvd drive and choose the program you wish to run the disc
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
