SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
Posted on Jan 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flash drive repair
My flash drive is not registering on my computer and any other computer in the office it was working fine yesterday. i need to get my information from it. what can i do
  • 9 more comments
  • bdesilets Jan 09, 2008
    I had the same problem. The other computer I used didn't have the drivers installed so I was just pulling the Cruzer out. Now, it won't show the F drive on my computer :(
  • Anonymous Jan 10, 2008
    same problem. owned it for 4-5 months before it died.
  • suresh158 May 16, 2008
    2GB everon flush drive is not working it was worked till yes'day
  • Anonymous May 18, 2008
    my flash dive says it needs formatting then a message appears data write protected what can i do
  • Anonymous May 19, 2008
    I have the same problem.
  • Anonymous Jul 01, 2008
    my flsh drive registereson my computer but will not open. a first, the problem was just it was write protected but then, the computer will no longer read the drive
  • ktln Jul 10, 2008
    I was typing a paper on a friend's computer when my SanDisk Cruzer just quit. the light went out and it wouldn't register anywhere or on any other computer. I've taken it to a few IT places and they said I would need to send it in and it would be around 500 dollars. I've been doing some internet reseach to no avail.
  • Anonymous Jul 10, 2008
    i bought a new sony usb flash drive of 1GB, i checked the properties,and discover that it is an empty one.
  • Anonymous Jul 15, 2008
    SanDisk 2GB usb flash srive
  • s_sitai Jul 22, 2008
    it was working yesterday, and when try again today, the computer would not open the docs from the flash drive.
  • firezone918 Jul 22, 2008
    even i plug my pen drive to computer but itn't responding and getting hanged
A
Anonymous
Flash drive not working some problem i need data
A
Anonymous
All dead buddy!!
Just buy new one!!!
Dean Joly
Level 3:
Master:
  • Master 788 Answers
  • Posted on Jan 10, 2008
Dean Joly
Master
Level 3:
Master:
Answers
788
Questions
Helped
291729
Points
2025
Not much I'm afraid. Sounds like it's dead, happens with thumbdrives sometimes, especially if you pull it out without stopping it or ejecting it properly first. I've heard of software that can try to recover files from corrupted thumdrives but if it's not working electronicaly with the computer it's useless. A data recovery service my be able to access the flash chip on the drive directly but this would cost a lot I'm sure.
I cannot get my cruzer glide flash drive to open up and let me access it on my Windows 7 which is an emachines
As the pen drive works fine on your laptop there is no problem with you pen drive the problem is with PC, Formating the PC might solve the problem
1helpful
Suddenly, my 500GB Seagate external hard drive couldn't mount on my iMac. It was working fine till yesterday. I connected them to the Mac USD port, and the light in the seagate is blinking... Any
I can only comment generically:
I would try to uninstall the drive on the OS. Then re-start the computer. After the re-start, connect the drive and see if the drive re-installs itself.
If the error persists, then the drive is indicating failure. To absolutely verify if it has failed, take the drive to a store where there are MAC computers and try the drive on one of their computers to see if it works.
A continuous flashing LED on most devices where the LED does not normally continuously flash is an indication of a failure of the device. Some devices will flash an error code when designed to do so, and if possible.
Jerry G.
My usb device was working fine until yesterday when I plugged it in and I kept getting an Unknown device error with the following message: "Windows has stopped this device because it has reported...
Code 43 errors are nearly always caused by a driver issue. However, since you have tried the device in several different computers with the same result, I believe that your flash drive has gone bad or become damaged. Unfortunately this is not an uncommon problem with flash drives. Like any storage device on the computer, make sure you are backing up what is on your flash drive.
I hope this is helpful to you
PNY 8GB Flash Drive - PC Will not recognize
Have you installed a scanner/another external USB drive since first trying your Flash drive? If so, try unplugging that and re-insert your Flash drive. I had this problem and a friend suggested this and it worked!
1helpful
Flash drive repair
It sounds like your media is malfunctioning (electronics).
For this type of problem, we offer a data recovery service.
You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Lexar with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
[email protected]
1-866-603-2195 ext 103
LC Technology International
1helpful
2answers
DOESN'T WORK
THERE ARE PASSWORD RECOVERY SOFTWARE OUT ON THE NET SOME AND FREE WHICH RECOVER OFFICE WORD, EXCEL AND OPEN OFFICE ETC
Flash drive repair
Some times if a flash drive is not ejected, if it is just pulled out, it can wipe all information. I learnt the hard way, make sure you eject each time.  Sorry if this is already known, some times it can be hidden if the file attributes  have been set to hidden. Try looking in you view option and see if they are set to hide files set to hidden.
hope it might help  Mr Fixitcv12
Drive Installation
Yes, you can just install your software and the drive but its best that you register immeidiately. They have decent customer service where they will replace you broken drive with a new one, if it dies...that happened to my first My Book Pro Edition drive...so be careful...if you are rich and can afford 1000 to have your lost data recovered, then fine. Im not rich and cant afford that so i lost ALL my data (500 gb) on my first drive. Because I registered it, I got a free drive four or five days later, if you have a credit card. Then i shipped them my old drive. Unfortunately, my new drive was fine for a year and died yesterday, again, ive lost ALL my data...consider making an additional backup of things you really NEED. Spending a 100 dollars just for that kind of back up is much cheaper than 1000 to recover the entire drive. Hope that helps. CJ Plourde
No communication
Is it displaying in device manager or it is not at all detecting. In that you may try with it some other system and same problem persist, there is possiblilty for damage. send it for warranty calim. Pen drive easily does not die. Check it in other system.
Any application or data is talking each other with computer and usb drive, then it gives warning try to close all application or any virus infection is there.
2answers
Imation Swivel Flash Drive Cant detect
is it several times that youve used your flash driver at your office? and which side of the usb port did you plug it? coz when it is your first time to use your flash drive at your office and your plugging it at the front side of the PC. well there might be something wrong with connection and may cause damage to the board of the flash drive. if it your using it several times, well try to check at your PC, then do the following specs:
my computer (right click and select manage)
and under manage window ( select disk management )
try to see if your flash drive registered (you can see the drives of your PC) and see if theres a volume (either raw/ or theres a partition on it).
if not, well the board of your flash drive might be damaged, mostly these were caused by the power of the system, fluctuation is one of them, then improper plugging of the flashdrive.
Top SanDisk Computers & Internet Experts
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
