Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181) Logo
Posted on Nov 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Freezes - Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181)
Anonymous
Level 3:
Guru:
  • Master 1,738 Answers
  • Posted on Nov 15, 2009
Anonymous
Master
Level 3:
Guru:
Answers
1738
Questions
Helped
470871
Points
4963
You may not have enough computer power to run it. Try shutting down some running programs to see if that helps, if that doesn't do it you don't have enough computer power. Those takes a lot memory to run.
2answers
Freezing Ricotta cheese? Is it possible?
Can You Freeze Ricotta Cheese?
Allrecipes https://www.allrecipes.com > ... > Freezer
Jul 13, 2020 - Ricotta is actually listed among the worst cheeses to freeze on our guide to freezing cheese. But just because it's not ideal doesn't mean it's ...
Jan 16, 2014 • Cooking
How to freeze avocados
try doing an avocado puree before freezing it, lasts longer and tastes better than freezing the whole avocado fruit.
Dec 11, 2013 • Cooking
Freez plugs
Yes. Most all water cooled engines used in automobiles willutilize freeze plugs in their respective design. The freeze plug is there to act as a weak point should the water located in the water jacket of the head freeze and expand. Without the freeze plug, the metal of the head would crack when the water freezes and expands.
Cell freeze 3 rows together at a time.
Freeze a Row in Microsoft Excel
Microsoft Excel 2010 can freeze, or lock, a top row as you scroll down the worksheet.
For example, you may need to keep the top row of column titles visible at all times.
The "View" tab on the command ribbon contains the "Freeze Panes" button in the "Window" group.
A single row or a range of rows can lock through the "Freeze Top Row" or "Freeze Panes" options.
Open the Excel worksheet.
Click the top row heading.
The row heading displays a number just left of the first column of cells. The selected row appears shaded.
Click the "View" tab on the command ribbon.
Click the "Freeze Panes" button in the "Window" group.
A list of options appears.
Click the "Freeze Top Row" option.
A black horizontal line appears on the worksheet.
This line indicates the locked row that stays on the screen as you scroll down the worksheet.
http://office.microsoft.com/en-us/excel-help/freeze-or-lock-rows-and-columns-HP010342542.aspx?CTT=1
Freeze or lock rows and columns
also
Use Freeze Panes in Excel
Scrolling down to look at a number and then scrolling up to make sure the number you looked at is under the header you expected is not an efficient way to view a spreadsheet.
The Freeze Panes feature of Excel allows you to freeze the labels of your data in place while you review the data.
Follow the instructions in Section 1 to freeze the top row or the left column.
Freeze multiple rows, multiple columns, or rows and columns, by following the instructions in Section 2.Freeze the Top Row or Left Column
Open the Excel spreadsheet.
Navigate to the "View" tab on the top menu.
3 Click on "View," then click on "Freeze Panes." A drop-down menu opens.
Select the "Freeze Top Row" option to freeze the top row.
5
Select the "Freeze Left Column" or "Freeze First Column" option to freeze the left column.
6
Freeze the top row by using the keyboard and sequentially pressing the keys "ALT, W, F, R." Ignore Steps 3 through 7 if using this choice.
7
Freeze the left column using the keyboard by sequentially pressing the keys "ALT, W, F, C." Ignore Steps 3 through 7 if using this choice.
8
Unfreeze panes by repeating Steps 3 through 5 and selecting "Unfreeze Panes" or sequentially press the keys "ALT, W, F, F."
Freeze Rows and Columns, Multiple Rows, Multiple Columns, or Multiple Rows and Columns
9
10
Freeze column(s) and row(s) at the same time by selecting the cell to the right of and below the location you want to freeze.
11
Freeze multiple rows only by selecting the cell in the left (first) column below the rows you want to freeze.
12
Freeze multiple columns only by selecting the cell in the top row to the right of the columns you want to freeze.
13
14
15
Select the "Freeze Panes" option. You have now frozen the columns or rows, or columns and rows you designated.
16
Freeze panes using the keyboard by sequentially pressing the keys, "ALT, W, F, F." Ignore Steps 5 through 8 if using this choice.
17
Unfreeze panes by repeating Steps 5 through 7 and selecting "Unfreeze Panes" or sequentially press the keys, "ALT, W, F, F."
http://office.microsoft.com/en-us/excel-help/freeze-or-lock-rows-and-columns-HP001217048.aspx
http://office.microsoft.com/en-us/excel-help/demo-hide-or-unhide-rows-and-columns-HA010241040.aspx
Hide or show rows and columns
Where is the freeze plug located
The engine in your Ford Explorer has freeze plugs, also called expansion plugs, mounted in the sides of the block. Freeze plugs are supposed to protect the engine block if the water in the engine freezes -- the expanded water is supposed to push out the freeze plug, although that doesn't always happen. Freeze plugs are made of thin steel compared to the engine block, and even with an anti-freeze mixture the plugs can rust out and require replacement.
Read more: How to Replace a Freeze Plug on a 1992 Ford Explorer ' eHow.com http://www.ehow.com/how_7670495_replace-plug-1992-ford-explorer.html#ixzz2IBxfNrjb
What's the freezing phase in the freeze-drying process?
The main stages of the freeze-drying process are placing the material in the freeze-drying flask, rotate the flask in a bath which is cooled by mechanical refrigeration in a larger scale freezing is usually done using a freeze-drying machine
12helpful
4answers
My deepfreeze didn't show in my taskbar how i can disable it?
I understand that you would like to disable the deepfreeze software installed on the computer.
One or more methods can be employed to enable/disable (Freeze/Thaw) Deep Freeze depending on the version being used.
A) Locally at the workstation (Deep Freeze Standard and Enterprise):
The following steps can be used to disable (Thaw) Deep Freeze:
  1. Hold down the SHIFT key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6. A Password dialog is displayed.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering a password. The Boot Options dialog is displayed.
  3. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. The same steps can be used to enable (Freeze) Deep Freeze. The only change is to select "Boot Frozen" instead of "Boot Thawed".
B) Remotely via Deep Freeze Command Line Control (Deep Freeze Enterprise only):
Deep Freeze Command Line Control (DFC.EXE) can be used to Thaw/Freeze Deep Freeze through a script or batch file. More information about using this utility can be found in the Deep Freeze Enterprise user guide available at:
http://www.faronics.com/documents/DF6Ent_Manual.pdf
C) Remotely via the Enterprise Console (Deep Freeze Enterprise only):
The Deep Freeze Enterprise Console can be used to Thaw/Freeze a workstation using the following steps:
  1. Select the workstations to Thaw/Freeze.
  2. Click the "Reboot in Thawed state" button to Thaw the selected workstations. The workstations should reboot and appear in the Console in a Thawed state.
  3. Click the "Reboot in Frozen state" button to Freeze the selected workstations. The workstations should reboot and appear in the Console in a Frozen state.
Please try the steps and I am sure you would be able to disable the deepfreeze software.
I am not sure on how to wire the freeze protection wires to the time clock. i know they must go to the load side of the clock for the main pump but will this reverse the power back into controls and short...
Here's a 240V diagram with clock timer and freeze control:
Add a comment if explanation does not fit your exact timer:
See image full size:
http://waterheatertimer.org/images/Freeze-protection-500.jpg
Here's how freeze control works:
Freeze control is like regular timer, except it turns ON by thermostat instead of time-clock
Freeze control turns ON pump whenever thermostat kicks on.
Both clock-timer and freeze-control are wired to pump in 'parallel' so to speak.
Think of it as having two controls wired to same pump...
Both controls can turn pump ON-OFF.
If one turns ON, and other is OFF ... then pump is ON.
If both are ON, then pump is ON ... and electricity just flows around on extra wires.
If both are OFF, then pump is OFF.
Say it's below freezing all day.
Freeze control circuit is ON all day ... pump is ON all day
Clock timer turns ON > but circuit is already ON, so timer just opens more wires for electricity to flow around on.
When clock timer turns OFF > freeze circuit is still ON because it's below freezing ... pump is still ON.
240V wiring:
Power leads coming from circuit breaker go to terminals 1&3 on clock-timer
Same power leads connect to freeze-control-black and freeze-control-red.
Or connect freeze-control-black and freeze-control-red to terminals 1&3
This action puts power to clock and power to thermostat
Pump wires connect to terminals 2&4
Same pump wires also connect to freeze-control-blue and freeze-control-yellow.
Or connect freeze-control-blue and freeze-control-yellow to terminals 2&4
This action connects pump to both freeze-control and timer.
When either clock-timer or freeze-control turn ON, then pump turns ON.
141helpful
3answers
Freeze panes doesn't work in mac excel
HOW TO FREEZE THE TOP ROW OF EXCEL FOR MAC:
Wow - using the above ideas I figured out how to freeze the top row!!! Thanks guys!! Here's how:
1.) Use 'Normal' View (i.e. look up at tool bar, hover over 'View' and make sure 'Normal' is checked)
2.) Select cell B2 (only the cell, not the row or the column)
3.) Click 'Window' (from the tool bar at the top of your screen)
4.) Click 'Freeze Panes'
...et voila! :-)
Top Hauppauge Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
