Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
This
is a text box. This can be turned off under the closed captioning.
There should be a cc button on your remote or the closed captioning
features can be accessed from your television's menu. Turn closed
captioning completely off to get rid of these text boxes.
Keep in mind that closed captioning can also come from your cable box or satellite receiver as well.
I had the exact same problem yesterday. It took me 1 hour and 45 minutes to find a solution. Here is the solution: It is not a stuck button or the television being 'posessed' that is resulting in the menu cycling. It is the fact that the television is in the DEMO mode. I was able to read the manual for this television online at the Toshiba website. On page 30 it states 'To stop the DEMO mode press 'recall', ''exit', or 'power'. Unfortunately the 'recall', and 'exit' button are on the original remote which I no longer have. The power button on my model is broken. I use the cable box to 'turn on the television'. In reality, the TV is never off, it is just showing a black screen when the cable box and DVD player is off. I suspect this defect in the power button has occured on other TV's experiencing this problem. I was able to push the broken power button to the inside and side of the television casing exposing a round circle that the power button pushes when the power button is not broken. I pushed this small circle to turn the television off. After about 5 seconds I pushed the button again and the television went on without the annoying menu popping up. Just unplugging the television and plugging the television back in does not work. You need to be able to push the power button, or one of the other 2 buttons on the remote previously mentioned. Also on page 30 it explains how to activate the DEMO mode. It's not too hard to accidentally do, especially when you have kids pushing buttons haphazardly. I hope this helps someone outthere in cyberspace! Kevin
in the customer menu--find the closed caption settings---you will most likely find the set has been set to TEXT 1---with the remote select either CC1 or OFF---the black box was for text (books) and was not ever used much---usually someone engages it by accident
Note that the large black box goes away when pushing buttons on the tv (ex: the black box will disappear to show the volume setting when changing the volume on the tv but it will cover the picture and the menu display of the dtv box).
This is caused by the closed caption setting of the television set NOT the captioning of the converter box. To fix this you must open your television's menu, find the ccd/closed caption option, and turn it off. This is a frustrating problem as when most people are told to shut off the captioning they try to do so at the box.
Normal dtv box captioning will appear as a small text box at the bottom of the screen as you would expect - not as a giant black rectangle that covers most of the screen. If you do want to shut this off too you will find that you can't do it through the usual menu options (the menu will only allow changes to font, color etc.) - there should be a ccd button on the remote that when pushed will scroll through ccd-1, ccd-2,... off.
It sounds like a text box that isn't receiving any text. If it covers almost the entire screen, then you might have accidentally got the settings into DEMO mode. It could also be a box for closed captioning, but that usually covers just the lower part of the screen. Either way, the solution is to go into the setup menu and restore facotry presets.
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
Just happened to see your black box problem associated with your T.V.; Thought I would pass along an idea for you to check into, and let me know if it helped...Check into whether or not it has a onscreen text block mode, if it gets into this mode by accidentally pressing the wrong buttons on the remote and or TV, it could and I have seen, at least with zeniths, a big black box which will cover the whole screen except for a 2 to 4 inch border around the box and outer edge of the screen...if this is the case, find someone familiar with the correct setting for the set associated with this problem, and get it back into the right mode....Hope this helps..T.
