SOURCE: Stopping cold air
Depending on where it is vented you probably wont be able to stop the air. Take the grill out and see if there is a door flap that is supposed to close when the fan is off. If not your out of luck.
SOURCE: Hello-I am being given a Jenn-Air electric range
Yes the ductless fan will work for you. I have that setup here at my house. Just make sure that you have a charcoal filter installed in the microwave where the air comes out on top. If it is already vent less the filter is probably already there.
Good Luck and Please Rate FixYa!
SOURCE: we have a twenty year old electirc jenn-air range
The problem may well be a loose NEUTRAL wire to the range. At the wire terminal on the range check for power from each supply leg(L1 to N) and (L2 to N) to neutral(should read 120 volts) and across each power leg (L1 to L2) should read 220 volts.
If you in fact have 220 volts into the range with good neutral contact the problem is a bad neutral(ground) in the wiring harness inside the range.
SOURCE: Jenn-Air model svd48600. Gas stove top, electric
The switch for the optional grill attachment is activating...pull the tray/pan on the left side that holds the two burner grates toward the front...it should shut off. To correct the problem permanently, you'll need to adjust the position of the switch. The switch gets lose over time and slides on its mount until it gets out of range. The purpose of the switch is to activate the blower continuously when using the optional grill accessory. When you remove the left-side grates and the tray/pan the grates set in...you'll notice a protruding piece of metal on the front of tray/pan that fits into a hole in the cavity where the tray sits. Inside that hole is the switch that is out of position. Getting at the switch to adjust its position is not difficult, but you need to remove the upper front panel...KLS
