It has features like MODE,SET/EL,ST/SP, RESET. The watch also has on the face plate rim -9GMT,-3GMT,+3GMT, +9GMT. It also is Atomic. I can't seem to set it right. There were no instructions in the box, and I didn't notice that fact till I opened it up.
I need a manuel in order to set the time on my cl-5008 Columbia All sport Watch which I recieved as a gift. Thank youI need a manuel in order to set the time on my cl-5008 Columbia All sport Watch which I recieved as a gift. Thank you
AnonymousMar 25, 2008
Did you find how to set the time, I have te same problem.Did you find how to set the time, I have te same problem.
AnonymousNov 04, 2008
Can't figure out how to set the time.
You can't post conmments that contain an email address.
I found it finally, but she told me I have to send in my watch (for $27.00) they can't just send or sell me a band ... The watch was $39.00 ... PLEASE!
Good luck, I hopr this helps you!!!
Columbia by Fossil Customer Service Contact Contact this seller Phone: 800-449-3056
Press and hold "set" until the "Chime" screen comes up. Let off "set" and then press "mode" - This will take you to the clock. adjust the numbers by using "st/sp" and "reset". Use the mode button to cycle through the hour, min, sec and date.
When The Watch Is In Normal Time Mode, Press The "SET" Button. Then Keep Pressing The "ST/SP" Button Until The Time Is What You Want. Then Press The "MODE" Button To Move On To The Next Field. When You Are Completely Done, Just Press The "SET" Button Again. Hope This Helped
Ple disregard all prior instructions. They are either wrong or a step was forgotten. Press "set" for 5 seconds. Then "mode" until you see 12-Hr flashing in the window, then press "ST/SP" until you see 12-Hr flashing, then press "mode" again until you see the word "hour", and the actual hour is flashing. At this point, you may increase time by pressing the ST/SP button or decrease by pressing the "Reset" button, then the "set" button. Enjoy!
Press mode til you get to time then press and hold set. Once the hour starts blinking press the ST/SP button to set the time, then press set again for the minutes and do the same thing again. This should let you set your watch.
HOLD "Set" for 3 seconds then use "Mode" to browse through option When you get the time setting hit "St/Sp" to set the time When you're done press "Set"
Alright, so the actual solution probably revolves around the fact you are stuck on "T2" time mode. This is found by a symbol that reads either "T1" or "T2" directly above the seconds. So first make sure you are in "T1" by holding the ST/SP button first, then holding the SET button second and simultaneously. After holding both for a couple seconds, the mode will switch from either T1 to T2 or T2 to T1. Once you get the T1 to be selected, you can then press and hold the SET button. Once that is held long enough, a menu will pop up saying "Chime" as the first display. Press the Mode button to start displaying the other features, such as hour, minute, second, month, date, etc. To make changes within a selection use the ST/SP and RESET as up and down changes. When you are all done and back to the Chime feature, you can press SET to exit out of the menu.
As a side note, the T2 function is based off your T1 time, so if you are in a different time zone, you can offset the time by however many hours you off from the T1 time - but the key is to get the T1 time set first.
