Duravit 0910100005 Happy D Toilet Cistern  - White Logo
Posted on Nov 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After cistern refill outflow into toilet bowl continues to dribble in - and you can see a slight flow into the bowl and every so often we hear the cistern refilling a small amount to compensate.
Anonymous
Level 3:
  • Master 399 Answers
  • Posted on Nov 15, 2009
Anonymous
Master
Level 3:
Answers
399
Questions
0
Helped
177510
Points
1001
Hi i would suggest your ball valve in the cistern needs ajusting remove the top of the cistern you will see the ajustment screw at the end fo the ball **** arm hope this helps
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 17, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7600
Points
No ball vavle in cistern just wont stop filling over flow in the toilet
  • Anonymous Oct 17, 2012
    no ball vavle in cistern just wont stop filling over flow in the toilet
How do i fix a leak from the cistern to the toilet bowl
There are bolts attaching the tank to the bowl check to see if they are correvtly tightened after you check to see if the gasket is properly seated.
Dec 25, 2014 • Home
tip
FIXING A TOILET THAT WILL NOT FLUSH!!! a simple but very effective money saving...
This simple how to, is based upon most lever operated toilets, with the cistern mounted above the toilet bowl. The make and model of toilet used for this feature is of the following:
Toilet and internal syphon
DUDLEY ELITEDudley S7 Cascade syphon
Problem:
My toilet will not flush, but the ball float valve is working and there is water in the cistern; no leaks present and the flushing lever is not broken or disconnected, what do I do?
Answer:
first isolate the water to the toilet or the main water supply to the house. Bail out the water from the cistern using a small jug or cup, (or you can syphon the water manually using a hosepipe or similar pipe, a towel to cover your mouth, and either a bucket or the toilet bowl) and remove water from the bottom of the cistern with a sponge.
Changing the syphon in a toilet that is not close coupled is far easier as you do not need to remove the cistern from the wall!
Undo the lower of the two large nuts beneath the cistern using a large pipe wrench or pair of water pump pliers, now disconnect the flush pipe and push it to one side.
Place a bucket or bowl beneath the cistern and undo the Nut which is immediately below the cistern (syphon replacing nut), some water may be released by the syphon, take note of any washers that are removed as new ones need fitting when replacing the siphon.
Unhook the lift rod from the flushing lever and remove the syphon.
Inside the toilet syphon, there will be a small plastic piece of sheet called a diaphragm; you can fabricate a replacement using the plastic title cover on a DVD case. Cut this to the exact same size and shape as the original part, and fit this to where the original diaphragm was. This is your new replacement.
Refitting is a complete reversal of removal, be sure to fit any washers (preferably new ones) that you have taken out. Ensure everything is tight but do not over tighten before refilling the cistern
on Aug 09, 2010 • Plumbing
3answers
MY TOILET FLUSH VALVE SEEMS TO BE CLOGED BUT I CLEANED IT IT WILL FLUSH BUT WONT FILL TANK YOU CAN HEAR WATER WANTING TO COME OUT PLEASE HELP
Hi Juan
Unfortunately we can't see what you can see. The problem must be right in front of you but you are missing it. Eg Parts / Seals in backwards.
If you can't figure it out and it's that urgent then call a plumber.
Good Luck
Nov 02, 2014 • Home
How to mend a running gural vitrifiye toilet cistern
With lid removed, look down into it and remove and replace the black rubber thing in the center. This is the flush valve and is worn to the point where is no longer provides a tight seal allowing water to pass and run into bowl. Also, could be something underneath it not allowing it to seat properly.
Aug 26, 2014 • Home
Grohe service
toilet will need syphon replacing. the lid should lift of the cistern, some have the push buttons screwed down to the syphon and to remove them just turn the ring around them anti-clockwise.
Aug 22, 2014 • Home
1helpful
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 • Home
Leaking toilet from overflow
if you flush and the water continues to run into the bowl the it is the flush washer that needs repalcing
If that water shuts off and the cistern fills and then continues so that it flows down the over flow pipe into the bowl the it is the water inlet control washer that needs replacing
1helpful
Water running into the bowl after flush and refil
IT SEEMS TO ME THAT THE BALL-**** (FLOAT SWITCH) IN THE CISTERN IS SET TOO HIGH UP. THERE ARE MANY DIFFERENT MODELS BUT ALL SHOULD BE EASILY ADJUSTED. HAVE A LOOK INSIDE THE CISTERN AND ADJUST THE FLOAT SO THAT THE WATER STOPS AT A LOWER LEVEL. IF THE WATER IS CONTINUOSLY FLOWING INTO THE CISTERN WHEN FULL YOU MIGHT NEED A NEW INLET WASHER
4helpful
Water continually running into my toilet bowl. how do i make it stop?
IF YOU PRESS UR BALLCOCK DOWN IN THE CISTERN YOU WILL STOP THE WATER DRIBBLING IN THE TOILET ,JUST VERY SLIGHTLY BEND THE METAL BAR IN THE MIDDLE AND IT WILL STAY DRIP FREE,OR PUT A LITTLE WEIGHT ON THE METAL BAR NEAR THE BALLCOCK...ROB
Sep 05, 2010 • Home
Toilet trouble
Based on the phrasing of your question, I'm thinking that the bad noise happens for the first time when the valve opens to start filling (this happens when you first let water into the bowl) and then again when the valve closes (when the cistern is full). Valves sometimes have a high-pitched squealing noise when it takes a long time to open or close this valve. Sometimes, you can make it go away by turning the screw to adjust the height that the ball/float has to be in order to shut off the water (the more horizontal, the longer it takes to shut off the flow, and the longer the noise continues). Sometimes, this is just caused by an aging mechanism and it turns out to be quicker and easier to just replace that part of the toilet (they make replacement kits that are very inexpensive and easy to install).
Top Duravit Home Experts
Mike Cairns
Mike Cairns
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Duravit Home Expert? Answer questions, earn points and help others
