Washing Machines Logo
Posted on Jan 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont work at all
Washing machine wont turn on
  • 5 more comments
  • waylesies Feb 07, 2008
    I am having a similar problem:
    White
    Kenmore
    2.1 cu. ft. Compact Portable Top Load Washer
    var omEvt="prodView";var omPrds=";02644722000";
    Sears item#
    02644722000
    Mfr. model#
    44722
    326054679
    i plug it in and the buttons light up- but then i push them and nothing happens!
    any help is much appreciated
  • Anonymous Feb 14, 2008
    plug in lights up set cycles filled and that was it
  • lukeron Feb 19, 2008
    machine turns on powers up lights up all lights but then pressing the buttons does nothing then after 5 secs the lights go out and in the wash progress panel the lights scroll one at a time from left to right then right to left continually . washing machine is a fisher and paykel smart drive 601 model number is GW601-F
  • Anonymous Jul 08, 2008
    Kenmore front loader. The wash cycle stopped in the middle of washing a small load of wash.I pressed the buttons on the front panel and no lights show up. Can't get it to started. Door is locked and my clothes are stuck inside the washer. Tried pulling the plug and nothing happens. HELP!!
  • CamachoDe Jul 09, 2008
    wont turn on
  • Anonymous Aug 27, 2008
    i have the same problem with a crosley front load
  • Anonymous May 11, 2010
    Need to know the model number and serial number before I can assist you.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 27, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
155
Points
Our Maytag MAV 8000 top loader suddenly will not start. Has power to outlet, has power to washer control panel. Does not send power to motor from panel indicating trouble in control panel.
I think it may be a bad timer but other than repair shop have no way to know for sure.
Anonymous
Level 2:
Scholar:
  • Expert 196 Answers
  • Posted on Jan 15, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
196
Questions
Helped
113254
Points
300
My washing machine wont turn on, it is plugged into an extension lead which also supplies the power for my dishwasher. the dishwasher works fine but the washing machine wont turn on at all, the lights...
It is nothing to do with the extension lead you are using, sounds more like a board problem to me, or another fault causing the lights to flash.
2helpful
My washing machine drum wont turn. The washing machine fills with water then just sits with water in it. It will drain but wont spin It worked fine yesterday, but today nothing. When I turn the drum by...
hello. if it don't turn then it could be the brushes on the motor also check the interlock on the door. any spin problems could be the module control board get back to me if you still have problems
regards
shaun
need a code for me ascent tv
Zanussi washing machine drum will not go round at all
Tracy
The bearing may have siezed or you have something jammed between the drum and outercasing
It wont finish washing
open and close the lid a few times. can you hear any clicking noises, you should hear the lid engaging the lid switch. if the machine doent think lid is closed it wont funtion( safety reasons)
2helpful
Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
