Do you have the original disk for the Futura software? Which version of the software do you have? Do you have the 32-bit or the 64-bit version of Windows 7? (To check your version, click Start > Control Panel > System and Security > System. If you see x64 at the end of the OS version, then you have the 64-bit version. Otherwise you have the 32-bit version of Windows 7.)
For the Futura SES-2000 version 3 software:
If you have the original CD, then do you have an optical drive in the laptop? If you do not have an optical drive, you should get an external one (USB connection); these can be gotten for ~$50 or less. (Make sure to have the laptop on AC power when installing software.)
You should be able to start the installation of the Futura software from the CD. For details on the 64-bit install:
http://www.futura-support.com/files/Futura%2064bit%20Installation.pdf . In the 64-bit install, you will click OK on several error messages. Then download and install the patch from
http://futura-support.com/downloads/updates/Ver3_0_0_9.exe .
For older versions of the software, there are a few options, you could upgrade to version 2.5 or you can maintain a computer with an older version of Windows. (See
http://www.futura-support.com/downloads/ce150.html and the Service Updates links in the lower left hand corner.) For the older version of Windows, you can keep a second machine with that OS, a dual boot computer with the OS, or a virtual computer with the older version. If you have Win7 Pro or Ultimate or upgrade to one of them, then you can run a virtual copy of XP for free. Download and install in order: Microsoft's Virtual PC and the XP mode software. Then install your Futura software to the XP computer (as if it were regular OS) and connect the sewing machine and transfer the files for your embroidery. There are other virtual computer programs (Parallels and VMWare). However, XP mode is the only way to avoid needing a licensed version of the older Windows OS.
I hope this helps.
