Hi there. Maybe your TV is not equipped for S channel reception.
Channel 73 falls into the S band; (21-69 is the normal UHF band.)
However in most cases, you must choose in wich band you scan your channels; (H, or S) I cannot imagine that this modern TV should not be equipped for S channels. Try manual channel search, where you'll probably find this possibility.
Sounds like the TV may need to be on ch 73 cable rather than 60 air. Try switching the TV to 73, if it goes to 69 then put back on 60, if goes to 73 good. Once you have that set go to your TV1 and bring up the menu. Go to System Setup (6) -> Installation (1) -> Modulator Setup (5) and change the TV2 setup to either cable if on 73 or air if on 60 and the picture should come in if everything's hooked up.
Hope that helped! You can email me at [email protected] if the problem persists.
Hello. This is usually an easy issue to fix. To get the DISH Network back on the screen, i have included a few steps:
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
If you are using an HDMI cable, then the TV will need to be on an HDMI input
If you are using Component cables, your TV will need to be on a component input. (Usually Comp 1 or 2)
If you are using RCA cables, then the TV will need to be on a VIDEO input (Usually Video 1 or 2)
If you are using COAX cables, then the tv needs to be on channel 3 or 4 (If you are at TV2, then the TV needs to be on channel 60 or 73)
I am assuming you have a dish network duel tuner. You can actually use any channel under 60 for the second t.v.. You can find all that information in that big pamphlet that your remote comes in. It also sounds like your in antenna mode, (please make sure your tv2 side is on before you do this) go to the second tv go to menu system set up scroll through until you see input type or something along those lines, make sure you select cable, then do a channel scan/ setup it should pick it up.
how old it the t.v. - most t.v.s are at least 181 channel compatible..hodge-podge words..in lay terms you have to have the capability on the t.v. to support X nbr of channels...also check to see if you have the menu set at cable or air...setting needs to be on cable
it sounds like the tv is already in cable mode, and that it is a older tv. some older tv's will only tune in so many channels. yours going up only to channel 69. if you have the remote for this tv, try punching in channel 73. if it doesn't tune in, then the tv will not recieve channel 73.
good luck
wg
