this is the most irrelevant and misplaced option (for controlling the size of a video captures by the video camera) (honestly even though i had the same problem , and somehow i find the option,and solve it ,but i`m nearly 1 hour wondering for the same option for you to solve your problem)
i had the same situation ,but mine was worse , my camera captured only 5 sec (you don`t have any problem for approximately unlimited amount of time for your capturing, even if you`re just using your 2GB memory card ,still is more than you can imagine : but remember your nokia 6303i classic ,could use additional storage device,and act as a host for that kind of device : you can easily connect your flash memory (by choosing the right usb adapter )directly to your nokia device,and your mobile detect this memory as a host , and all you need to do , is to change your saving contents location (actually , i connect my (8G Flash + 16G integrated ram reader) mp3 player directly to the phone by USB ,and through the os of nokia , i can browse , play ,locate,and set as saving place)
HERE IS YOUR SOLUTION:
the reason that your camera ,capturing time is limited in time , is for limit of the MMS (multimedia messages) ...
- go to your video camera
- in the option menu you will find setting/video clip length (set it to MAX AVAILABLE instead of for MMS messages)(its better to set your photo/video storage to memory card or other folder in case you have much more available memory and need to capture 2 days of recording)...
- IMPORTANT NOTE : it may you wont see the option the first time you select camera ,,make sure you select video camera/setting ,and the option will be there
(additional setting related)
so to correct this ,you must go to your messaging setting (who the **** think that the reason may be in there ) select MORE / Msg. settings / multimedia messages
and set the MMS creation mode free (or guided maybe works)instead of restricted
and the default timing ,is define limit in time,if the option restricted ,is selected
HELP ME : i`m killing myself to find a software solution ,for monitoring my video recording ,on my pc monitor ,(in case i want to record my self :while playin music ),and something that make n.6303i act like a web cam ,,,then i can use an application for video recording ,and synch my capture button with ,record audio from another port (for high quality studio sound )instead of her poor microphone ,,, as a matter of fact i did find a solution (named : mobiola screen capture for xxx(mobile models)
and it says ,that its supporting n.6303i ,,nevertheless the app for the device is in *.sys format ,and i never see (and nokia ovi suit say`s so :your mobile doesn`t support this type of ,,,,) is there anyone out there overcome with this problem before , the n.6303i get airial directly to the wall ?
I have the same problem - I even went to a 4 GB SanDisk Ultra II Compact Flash memory card, and it still doesn't work. Why can't I video in higher quality? HELP!!!
I have the same problem and it was owrking just a second ago!
