The manual says to go to direct tuning and simply tune to the staion, but no matter what setting im in ( A, B, C, or Direct) I cannot tune to any singlestation. Anyone have a similar problem? Im sure it just a slight problem Im overlooking but I can't figure it out.
You need to select your station then press the preset button then 1 thru 0 to store the station. repeat for the rest of yoiure stations you want to store.
Turn on the CD tuner by pressing the power button.
Enter your code numbers to unlock the device if it's necessary.
Use the tuning buttons to navigate to the AM or FM radio band.
Use the seek or manual tuning buttons to find the desired station.
Once you find the desired station, press and hold the preset button to save it to a specific preset location.
If you are having trouble with the CD tuner losing your presets, you may want to try resetting the unit to its factory settings. You can consult your owner's manual
If you have buttons on your radio that allow you to switch stations, it generally is simply a matter of pressing and holding the button in place for 10-15 seconds. The year, make, and model of the vehicle doesn't say much, as vehicle may have an aftermarket radio. Just find the station you want and if there is a are button presets, just push and hold it in. On most of my cars, old and newer that I have owned, confirmation of the setting is generally accompanied by a beep. Good luck! JD
hi, there is no auto presettingavailable. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER". 2. Press the FM/AM button to select a band. 3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it, 4 .Press the MEMORY button.( on remote) 5. Within 5 seconds, select a preset channel to store the station using the PRESET buttons of the remote control unit. 6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listeningpreset ed station ,Press the PRESET button repeatedly until the desired preset station is found. ok
The model number you posted is for a center channel speaker which has no controls, and not knowing the exact model number it's difficult to be specific.
Some Kenwood KDC models allow you to select one of 3 "tuning modes", 1) AUTO1 - Automatic search for stations; 2) AUTO2 - Search Preset stations; 3) MANUAL - Normal manual tuning control. If your Kenwood is one of these models, you need to set the tuning mode to MANUAL. For Kenwood Excelon HD receivers, direct access tuning is done by using the included remote. 1) Press DIRECT button on the remote; 2) Press number buttons to enter desired channel number; 3) Press DIRECT button again to exit direct tuning.
Setting Time 1 Press TITLE repeatedly until the time is displayed. For details, see “Displaying the Text” (page 13) 2 Press and hold TITLE for at least 2 seconds while the time is displayed. The time indication will blink. 3 Turn the Rotary encoder to adjust the hours while the time indication is blinking. 4 When the hour has been adjusted, press MODE. 5 Turn the Rotary encoder to adjust the minutes while the time indication is blinking. The time is automatically set 5 seconds after the minute adjustment. The time can also be manually set by pressing TITLE. • To synchronize the clock to another clock/watch or radio time announcement, press and hold MODE for at least 2 seconds after setting the “hour.” Minutes will reset to “00”. If the display shows over “30” minutes when you do this, the time will advance one hour. Listening to Radio 1 Press SOURCE/POWER until a radio frequency appears on the display. 2 Press BAND repeatedly until the desired radio band is displayed. F1 (FM1) F2 (FM2) AM F1 (FM1) 3 Press TUNE to select the tuning mode. DX SEEK (Distance mode) SEEK (Local mode) OFF (Manual mode) DX SEEK • The initial mode is Distance mode. Distance mode: Both strong and weak stations will be automatically tuned in (Automatic Seek Tuning). Local mode: Only strong stations will be automatically tuned in (Automatic Seek Tuning). Manual mode: The frequency is manually tuned in steps (Manual tuning). 4 Press or to tune in the desired station. Holding down or will change the frequency continuously. Manual Storing of Station Presets 1 Select the radio band and tune in a desired radio station you wish to store in the preset memory. 2 Press and hold, for at least 2 seconds, any one of the preset buttons (1 through 6) into which you wish to store the station. The selected station is stored. The display shows the band, preset number and station frequency memorized. •You will need to start from set up or you will not be able to set the mins
Your Sony is equiped for 5 AM presets and 15 FM presets.
1. Power your unit "ON".
2. Set the desired band - AM or FM.
3. Hold the "Mode" button down no more than one second. The "preset" indication just be gone.
4. Manually tune in the desired station you want to preset.
5. Hold "Enter" until preset indication re-appears. The number of the preset should be blinking.
6. Using the tuning buttons, change the the number to your desired "preset" number.
7. Push the "Enter" button to set the preset.
Remember, you can't have more than 5 AM presets (a mistake I made).
If you only get 1 station no matter what station you tune into, you have a ans electrical problem on the main board of the radio. Your tuning voltage is not changing as you tune thru stations. There is most likely a shorted or open transistor that supplies the tuning voltage on the main board.
There is no easy fix for this, you would need the schematic to find out why the tuning voltage is not changing.
If you know how to do electronic troubleshooting and have a multimeter and the schematic you can fix it with not to much trouble. If this is not the case, you will need to take it in to a service center.
Sorry that there is no easy fix for this problem.
Hi Gil, not sure what you mean by RE-setting presets but I assume your using a dock of some kind, and in that case you simply tune to the station you desire then hold down the preset number you'd like to set it to. It will overwrite the previous setting. hope that helps.
I haven't done this on mine yet, but on most you simply tune to the desired station then HOLD IN the preset button you want to assign it to until it blinks or some such indication of setting acceptance.
