When i start the cycle, the settings for hot water work, warm water is dispensing hot water, and when its on the cold setting nothing comes out and the washer makes a dull noise. i removed the hoses on the back, cleaned the screen, and checked to make sure that the hose is not the problem. the problem is in the washer. for the mean time i am going to switch the hot and cold hoses to trick the washer so i dont ruin my clothes. any suggestions on what to do?
Could be the cold water solenoid is stuck or broken, maybe a wire has broken or terminal worked loose.
You need to take a look inside and check the wiring, check the supply to the solenoid, etc. If the supply is good the solenoid is probably faulty. If there is no supply it is possibly the board or the controller.
SOURCE: bleach dispenser hose
To access the bleach dispenser hose you will need to remove the outside casing of your washing machine. Follow these steps:
1. UNPLUG the machine first.
2. Remove the console. You will have one of two types of consoles with two separate methods of removal.
a.
The first type is a matter of removing the two end caps of the console
by lifting up on the end cap from back behind the console and pulling
towards you. The cap should just pop off. There will be a groove
present on the top rear that you can gently pry with a screwdriver if
you can't remove by hand. You will need to remove the philips screw
under the end caps and the console will lift up. Be careful not to
break the plastic hinges that hold the console in place. You can lift
it up and lay it back over the rear panel in a resting position.
b.
The second type of console (usually found on some of the newer models)
has a retaining clip under each end cap at the front corners. You will
need to carefully slide a putty knife between the end cap and top of
the machine from the front. Push in to release the retaining clip and
lift up. This may be a little tricky trying to get both ends to release
together. The console lifts up in the same manner as described before.
Again, be careful not to break the plastic hinges that hold the console
on.
3. You will find two brass colored clips under the console.
Place a flat blade screwdriver in the clip groove on the washer top and
push away from you. This will release the retaining clip that holds the
case to the back of the machine. Remember how they came off, because
you will need to put them back in.
4. Disconnect the lid switch
plug from the connector. This is a white plug that is mounted
physically to the washer top casing.
5. Lift the lid and place
one hand under the front rim of the casing and pull up from the rear
towards you. The entire casing should lift off the frame.
6. You should easily be able to access the bleach dispenser hose at this point and make necessary repairs. This is also a good time to inspect the rest of the washer interior and clean underneath.
7.
Placing the case back on the frame can be tricky. Lift the lid again
and place one hand under the front rim of the casing. Looking down
through the lid, place the front of the casing UNDER the frame first
and slowly lower the rest to the back. There are two cleats on the
frame that must line up with two holes in the casing. Once the casing
lines back up
on the frame, set it down all the way and pull the back up to meet the
casing so you can place the brass retaining clips back in. Place the
clips in the groove on the back first, then push down until they snap
back into the hole on the washer casing top. You may have to use a
little effort to get them back in.
8. Reinstall the console.
I
know this seems like a lot, but it is simple if you follow the directions given.
Getting the machine case to line back up is the hardest part of the
procedure, but you can do it if you take your time. Let me know if you
have any further questions. I hope this helps you.
SOURCE: No hot water
Make sure your hot water supply valve is on first. If so then try reversing the hot and cold water feed lines and see if you get hot water when asking for cold. The water valve for the hot water side could be bad. Are you familiar with a voltage meter or know someone that can see if you valve coil is getting 120V when the machine is trying to fill with hot water. If not the control unit is faulty. If you do have the 120Vac on the solinoid coil and no water the either the coil is open circuit(bad) or the inlet is plugged. Most generally the problem is in the control knob unit.
SOURCE: Reimbursement for ruined clothes
you should never put bleach in the dispenser ,
unless it is colorfast bleach.
always add bleach diluted directly in the drum to prevent this from happening in the future.
the dispenser may never clear the bleach fully.
check is in the mail.
SOURCE: i have little suction when using the hose attachment
Check the hose for a blockage. If you remove the hose, if there is suction at the point where the hose hooks to the back of the vac, then the hose is clogged. If no suction there, check filters, make sure they are clean.
SOURCE: SOAP DISPENSER HOSE
take both star screws from under lugs on either side of the lid remove that then take soap drawer out if screws are not visable remove front facia panel the same screws which hold the facia will also hold the soap drawer in place as you lift the drawer you will be able to undo the hose to the drum.
