Question about Polycom SoundPoint IP 501 IP Phone
Polycom Soundpoint IP 501 - URL call is disabled
I get the message 'URL call is disabled' on the phone I just connected. The phone shows the phone number and goes through the set-up, but doesn't have a dial tone.
  • 4 more comments
  • kajham May 05, 2008
    have the exact same problem
  • Anonymous May 13, 2008
    how do i resolve the URL disable problem. it keeps returning, any suggesstions
  • abdutr May 28, 2008
    I had the same problem, I did the change:
    feature.9.name="url-dialing" feature.9.enabled=1
    But now, I see "service unavailable" on the screen???
    thx
  • jade1 Jun 17, 2008
    i have the polycom 550 and every day some one in our company has a phone withe the message url call are disable. Is there a quick fix for this.
  • dethcraft Sep 23, 2008
    We're experiencing the EXACT same problem..any help is appreciated
  • serf33 Jul 14, 2014
    I know this is WAY late but did jade1 or dethcraft ever figure a solution? I'm having the exact issue at my office.
  • 7 Answers
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Posted on Jul 02, 2009
If you are getting the error message URL dialing disabled, this means that the feature in the config file is disabled and the Polycom phone is not registered against any of the line's configured registration servers.
Posted on Nov 05, 2008
If you are using autoconfig make sure that the file sip.cfg has
Posted on May 21, 2008
I get this same problem. The phone icon turn white and "url call is disabled" I can place calls and receive incoming calls, but cant place outgoing calls, unless the phone is rebooted
Posted on Jun 01, 2008
SOURCE:
Soundpoint ip 501 cannot acees via browser
Are you using config files loaded from the server? If so, make certain they are properly configured. Also, make certain the phone does not already have an alternate configuration in it that points elsewhere...
Jul 21, 2012 | Polycom SoundPoint IP 501 IP Phone
I have a problem regarding my Polycom Soundpoint IP331. It doesn't boot anymore. It shows only an error which is error.cfg.
You need to reinstall all the files back onto the phone. You can get the files from the Polycom Website. You can also follow the instruction from my Polycom 501 Fixya blog to see how its done.
Jun 15, 2011 | Polycom SoundPoint IP 501 IP Phone
What does this message mean: Url call is disabled
This means that your phone will not dial a url number, i.e. sip://123456789@somedomain.com. This is generally a network or configuration error, and I would specifically make sure the phone either has static DNS entries entered or is receiving DNS entries via DHCP.
Mar 01, 2011 | Polycom SoundPoint 650 IP Phone - LCD -...
How to add the more softkeys in sound point ip 501
need to buy one soft keys station and that will connect to your master's.
Mar 29, 2010 | Polycom SoundPoint IP 501 IP Phone
Can ping my polycom 501 but cannot open with my
Have you tried a factory reset from the menu interface? Be careful if you do, and only choose "Format File System" as a last resort, and only if you feel comfortable enough setting up a FTP/TFTP boot server to re-provision the phone, as this option will erase everything, and then all it'll do is get stuck in a boot cycle until reprovisioned.
Feb 22, 2010 | Polycom SoundPoint IP 501 IP Phone
Connection Problem
I think you have to have the upgraded cable modem with the rj11 on the back in order to pull the voip dialtone. Hope this helps
May 14, 2009 | Polycom SoundPoint IP 501 IP Phone
Making a Polycom SoundPoint 501 work on an Avaya IPO
As you have probably found, SIP phones are not supported until R5, which just came out.
Nov 11, 2008 | Polycom SoundPoint IP 501 IP Phone
Just installing polycom 501 phones with nextiva
Ohh this mean, you did not register this extension on your phone system. Create this extension on your phone system. Be sure that password given on Phonesystem is also configured on phone too.
Oct 19, 2008 | Polycom SoundPoint IP 501 IP Phone
Dead Polycom 501
u have the cable plugged in backwards
check it
Jul 25, 2008 | Polycom SoundPoint IP 501 IP Phone
Polycom SoundPoint IP 501 IP Phone Logo
20,939 people viewed this question
Top Polycom Computers & Internet Experts
N8nNc
Tom Chichester
Dayton Computer
Dayton Computer
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
