Nokia N72 Cellular Phone Logo
Posted on Nov 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mmc not accessible in messaging option,elsewhere accessible
When i change my message memory from phone to memory card,i cannot access inbox,or anythng,not even new message...Plz hepl! n i can access mmc in gallery except for messaging!!
Anonymous
Level 2:
  • Expert 297 Answers
  • Posted on Nov 14, 2009
Anonymous
Expert
Level 2:
Answers
297
Questions
0
Helped
82019
Points
916
First u need to reset ur phone .delete all mgs ........then move the da megs on mmc...........then i hope it will work
1helpful
2answers
I want to save my txt messages on memory card..i"ve inserted 2GB micro SD...bt cant switch the memory frm phone to mempry card?? tell me..wat do i do??? help me out..
Nokia C3 cell phone is a good phone from the Nokia Corporation.
If you want to save the messages in memory card then you have to perform the following steps:
Go to Messaging menu
Move the cursor on Inbox
Go to inbox options
Choose settings
You will find the option other
In other option you will find Memory in use option
Choose the memory card memory.
Then you are able to save the messages in your sd card.
How can I change the inbox storage from phone to SD card? After 135 messages my phone reports that inbox memory is full.
hey hi buddy....
nothing to worry,go to message settings and change the message saving option from mobile to memory card and your problem will be solved....
thank you..take care
3helpful
I cant save my messages to my memory card
In nokia 3230 you cannot save the messages to memory card.You dont have option in this mobile itself.
Dont worry, please download MSV driveE software in your mobile phone so that messages can been directly saved in MMC.
Download the MSV software from below website
http://www.ziddu.com/download/8277766/MsvDriveE.jpg.html
After you downloaded it, you’ll find that you save file named MsvDriveE.jpg. Don’t worry! You just downloaded the right file. Rename the extention *.jpg, and change it to *.sis. Then you’ll get MsvDriveE.sis then install it to your phones.
But in this feature it just saves the incoming messages to the memory card instead of saving it to phone memory to keep the phone memory unused.But you cannot read your messages.
To read your saved messages in PC please install a software called as FE explorer.
You can download FE explorer from below website
http://gallery.mobile9.com/f/1210278/
Using this FE explorer you can copy the messages in your inbox and you can paste in any of the folder in memory card.Then you can open the messages in your computer using Note Pad and read the messages.
To copy please follow the below steps,
1.Select inbox from the main page in FE explorer.
It shows the messages in Your inbox,sent item,saved messages also.
2.Copy it and Paste where ever you want to copy in E:/ drive(Memory card)
3.Then you can put your memory card in your PC and can open up the messages in Note Padfd6f18b.jpg Thank you
1helpful
Message inbox was full, now cannot access anything
You should first delete files in your phone gallery manually before you go to your inbox. Delete pictures,videos or something that you don't need in your phone memory. Restart your phone to refresh the system.
Hope this could help you alot Thanks..
1helpful
Inbox doesnt oepn
Your memory card could be corrupt.
If you have a PC Suite for your phone then try to access other details from your memory card through your computer.
If you cant view your items in the memory card from the PC Suite then obviously the memory card is corrupt.
Reformatting your memory would restore it back to normal.
2answers
MEMORY DOES NOT CHANGES TO MMC
use ur phone setting and make the primary memory aur mmc then transfer all ur data to. ur msg are on sim not on phoone. u have to save them 1st.
May 04, 2009 • Nokia 6600
Memory card
Hi xxbooxx,
if ur memory card have erased only messages but not other mp3s and videos, etc. I have got the solution for it.
Go to messages, click options, and go to settings. Go to "other" option, there is a menu memory in use. In that change phone memory to ur MMC.
Then ur messages will appear in ur inbox.
Surely send me feedback and rate my solution too.
Dont forget to post clarification report of ur problem after the problem is solved.
Sajan([email protected] / [email protected])
Memory prblem
first foramt your phone memory .
After deleting all mess. from ur inbox[phone memory] go to inbox options and select settings then others then chage ur mess memory to mmc.
it will definately work..
Mar 20, 2008 • Nokia 6600
Memory card problem
i think the MMC card is the prob' try to format it first, if you still having the same prob.
try to change MMC....
Phone cannot access memory card
wipe your MMC card metal contacts carefully and insert it again, this happen beacause your mobile cant able to detect MMC from tour phone one big reason behind that is there is thin layer beatween MMC metal contact and phone cocnnectors contacts. so wipe that metal contacts of MMC and your problem will solved.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
