Without more tests, I can't be completely positive but the turntable motor is the likely problem. That is part 1-4 on the list above. However, it could be a wiring problem with the wiring to the turntable motor.
1st check the temperature fuse ( item 1-3 on this diagram)
If fuse is good have the HV rectifier item 1-1 checked.
If both check out good the most likely problem after that is the magnatron item # 1-8
Hi, if this unit is over the stove it has to come down. Table top, case has to come off. The monitor switch is a microswitch that is part of the door switches. PLEASE UNPLUG YOUR UNIT BEFORE WORKING ON IT. When you get it opened up, there's probably a diagram that will let you know which switch it is. Lookd it up and does list a monitor switch with fuse, but would not give me a part number. Hope this helps
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
Yes call shart help line, you can find it on 411.com or googles, with you model and them the part # for the bracket and ask them were you can purchase it.
You can also try sears with your model, there or a very excelent sourse for question's on parts, if they have this model they will have all info.
